mods list
Old May 25, 2012 | 06:36 AM
dieselkid's Avatar
dieselkid
mods list
ok so i am on deployment and just bought my 04 f350 shortbed before heading out.
i have a mod listing and just wanted input on goods and bad for each system, manly on the airdog fuel filtration system good or bad idea
airdog 150gph (for the future motor mods) any onw running this, i figure the water seporator is a really good thing, i think its easier to use then the 2 stock water seporators and such. i belive the kit goes from the tank stright to the lift pump, correvt incorrect. that is teh mod i want to do, yet from that tank sump to the airdog to the lift pump.
xdp fuel tank sump kit (allows all fuel from tank to be use without reducing fuel pressure at 1/4 tank when at wot also will be dropping the tank to clean and make installation super easier
blue spring
xdp coolent
ssbc v8 caliper with 4wheel kit- yes it expensive but i travel alot with the army and my town has a lot of bad drivers, i want to tow my other race/project vehicals and who knows what else. i am a furm beliver in stopping power
isspro turbo temp monitor as my turbo timer
there are other but this right now is at the top of my list. these mods i want to install while i have my R&R in a couple months
i am going to have the ficm looked at make sure its good.
what batteries are best, i was thinking optima yellow tops
bullet proof oil cooler and soon a bullet proof egr. egr has been replace already
Riffraff diesel auto dash kit with 6slot switch for auxilary add ons to come but maily for 2 gagues.
about gagues what are the gagues that are needed. i know oil, tranny, egt, boost, and a scangague, any others i should get?
is there any other really recomended mods i should look into or need to get.
Old May 25, 2012 | 06:45 AM
tex25025's Avatar
tex25025
I separated this, but I have no idea where you got this idea from. I have had a fuel PSI gauge on my truck stock and modified and I have never noticed a drop in fuel psi below a quarter of a tank. And I constantly look at my gauges.
Is this a programming "thing" in the early 6.0s? I know my 05/06 doesn't have it. Trust me, I've been WOT more then a few times.
Although I will admit that I don't let it go too long below a quarter of a tank, but I still haven't noticed a loss in pressure at WOT when I'm down there.
blue spring
xdp coolent
Some of those are redundant when it comes to your gauge list. The scangauge should be able to read all of those except EGT (I think it does allow for one expansion, but I can't remember if it's for EGT or fuel PSI). Although I would add fuel PSI in there as well as that requires an external probe like EGT.
I, however, would suggest an OBD-II gauge that allows for external probe expansion for both EGT and Fuel PSI, that way you only have to look in one area for all your gauge readings. Unfortunately, the scan gauge, best to my recollection, only does that for one.
As to the rest of your mod list, it all depends on what the end result is that you want for your truck. All out HP/TQ, or all out HP/TQ but still street and/or tow worthy?
Old May 25, 2012 | 08:48 AM
Rusty Axlerod's Avatar
Rusty Axlerod
ScanGauge isn't expandable it's OBD only. Every once in awhile someone will come up with a "new" gauge by figuring out some codes.
ScanGauge Capabilities
First, what it won't do:
Fuel pressure
Exhaust gas Temp
Low (crankcase) oil pressure*
These values are not monitored by the engine computer, there are no sensors under the hood so the SG can't see them.
What it will monitor:
Fuel Level
Battery voltage
Engine coolant temp
Engine oil temp
Trans fluid temp
Intake air temp (on 2 different sensors)
Injection control pressure
Injection pressure regulator
FICM (fuel Injection Control Module) main power
FICM vehicle power
FICM logic power
FICM sync status
Camshaft sync status
Crankshaft sync status
Fuel injector timing
Fuel injector pulse width
Fuel injectors 1-8 on/off commands
Radiator fan speed
Radiator fan duty cycle
Barometric pressure (ambient)
Exhaust back pressure
Turbo Boost (by tinkering with baro settings)
Turbo duty cycle
manifold absolute pressure
Accelerator pedal position
V-ref voltage
Trans shifter position (automatic)
Mass Fuel Desired
These are the main ones. People are still tinkering with codes for misfire counts on specific cylinders and there may be a couple more I missed. In addition to these gauges, the SG has a trip computer that calculates fuel mileage and trip time etc. It also scans for many (but not all) codes that may have been stored if there is a problem that turns on your Check Engine Light. It simply plugs into the OBD port under the dash so install is easy also, and finially, the price is right.
Now for the negative:
The price is inexpensive because it's inexpensively made. The display is LCD but the dots are pretty coarse and it can be hard to read (the color of the backlight can be changed which helps). Half of the gauges you will want to monitor require you to input long strings of numbers to "program" into the unit, it also must be plugged in to do that so you'll be sitting in the driveway for awhile when you first get it. and finially, it is what it is, there are no options to hook up additional sensors to allow it to display the values I mentioned in the beginning.
There are other monitors with touch screens that can be expanded to show the other gauges, like the Edge Insight or DashDaq. These monitors are considerably more expensive but the expandability is important and besides that they just look better. Back-up cameras, mp3 capability, and the ability to completely change the way the screen looks is pretty cool if your budget allows it.
Old May 25, 2012 | 09:14 AM
tex25025's Avatar
tex25025
Fuel pressure
Exhaust gas Temp
One user on here was saying that you can add an external probe to get I think EGT, but not Fuel PSI on the SG. Maybe it's a new addition to their gauges, I dunno. Or the user was wrong in their facts.
Old May 25, 2012 | 07:01 PM
dieselkid's Avatar
dieselkid
tex to talk more about the 1/4 tank issue. i dont know how offten it happens on common rails but i stilll own my 6.9l and that monster was a pain in the *** if you ever dreamed about getting beloe the 1/4 tank, also it was the best way to suck up any water and crap in the bottom of the tank. witch is why i want to uninstall mine clean it all out. that sump kit is pretty inexpensive and i am not a fan of running a diesel low but with a airdog and a sump kit i will be comfident it wont run air into the system like my 6.9l did. due to fuel slosh and that its was very easy to pull air into the system when under 1/4 of a tank. just because it hasnt happened doesnt mean i cant and wont.
thanks for the info on the SG were are all the codes?
wonder if its possible to open it up and add a bigger screen or the ability to modify the mother board to add a screen somewere else. humm i might tinker with the idea if i get time
Old May 25, 2012 | 08:18 PM
tex25025's Avatar
tex25025
First off, don't think of this along the lines of the older diesels, that'll get you into big time trouble with this one.
Second, the only 1/4 tank issue that I'm aware of has to do with the FASS pumps that didn't have long enough pickup line and it would start sucking air when you got below 1/4 tank. That was on the earlier ones and that also wasn't with the stock pump. Now I don't know if the AirDog has those issues too or not, but the fix is just longer line.
I don't know of any issue with the stock pump.
Old May 25, 2012 | 09:57 PM
Rusty Axlerod
Here's 99% of the codes, few more floating around here. Also the SG website has a list for the 6.0. Hot rod the SG hu? Cool idea.
Sg2 codes w/values
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=eHIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT*
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Per4mance
Nov 2, 2014 03:37 PM
Finz250
6.4L Power Stroke Diesel
Jan 9, 2014 12:44 PM
yankesfn2
Aug 4, 2012 09:40 AM
Sheryle
Feb 28, 2011 04:39 AM
caere
Jun 18, 2010 12:48 PM
