Brakes
Old May 24, 2012 | 05:16 PM
midsouth's Avatar
midsouth
Question Brakes
On my 83 f150 5.8 liter pickup, the one or two of the breaks are locking up. I drove a lot today running in-town errands. The pads are almost new and haven't had any problems until today. Any help would be appreciated.
Old May 24, 2012 | 05:52 PM
Gary Lewis's Avatar
Gary Lewis
I'm assuming that by saying "pads" you are talking about the front brakes, but you really need to be more precise in your posts as we shouldn't be making assumptions. Anyway, if it is the front ones my guess is that they aren't sliding like they are supposed to slide. The calipers are supposed to slide left and right to allow for wear and rotor runout, and if they don't then it upsets the balance. So, when the new pads were put on were the calipers checked to make sure they will slide?
Also, while the rear brakes are supposed to be self-adjusting, many of those mechanisms no longer work. In that case the rear brakes become less and less effective and the braking shifts more and more to the front. Has anyone checked the rears to ensure the self-adjuster works? Have you adjusted the rear brakes to make sure they are working properly? And, have you checked the brake fluid level?
Old May 24, 2012 | 06:20 PM
81ChopTop's Avatar
81ChopTop
Are they replacement calipers? If so, where did they come from?
I had the same problems on my old '83, but they smoked on the highway. Didn't even notice because the truck was loaded with steel. A lot of them use a phenolic piston, and some of the aftermarket ones bind up in time. Switched to a steel piston caliper and never had a problem again.
Old May 25, 2012 | 07:10 AM
82f100460's Avatar
82f100460
I've seen other threads on here where there was issues with the flex lines going to the calipers as well. Either the lines get kinked or the interior lining of the lines gets old and rots, then blocks the passages causing the calipers to not return and lock up.
If you replaced the calipers, did you also replace these lines?
Old May 25, 2012 | 08:30 AM
Grubbworm's Avatar
Grubbworm
Ok, I have to agree with everything everyone said, so far.
I also have a few things to add.
First, when was the last time the brake fluid was completely flushed? Here in Georgia it is recommended every two years, because of the high humidity level, and the brake fluids hygroscopic properties. Moisture can collect within the system and cause rust, which will cause internal parts not to function properly.
Second, when doing front or rear brake replacement you should always lubricate the proper points with the proper brake grease. I always use the green synthetic disc brake caliper lube.
I have some steel braided flex lines on my truck. They work very well, and will not expand like the rubber lines. Having said that, they will wear out like the rubber ones and need to be replaced, just not as often.
I would also say that if some or all of the brake parts have never been replaced and are original, then it would be a good idea to do so with some good quality parts. And do or have it done properly.
Good luck.
Old May 27, 2012 | 12:04 PM
midsouth's Avatar
midsouth
Thank you to everyone. I believe the brakes, lines, etc are original. Due to my limited experience, I'm taking it to the shop.
Old May 27, 2012 | 01:54 PM
Dave804's Avatar
Dave804
I'm betting fluid as well. How worn were the old pads? Someone might have added fluid to make the old pads compressible, putting on thicker pads increased the fluid level in the system beyond the acceptable max.
lockjaw73
1983 - 2012 Ranger & B-Series
Jan 28, 2010 07:08 PM
JTdesert
Mar 3, 2009 12:16 PM
Daviddc114
Sep 17, 2008 10:23 PM
Bookman
Mar 15, 2005 11:14 AM
c96drumm
18
Sep 13, 2003 01:17 PM
