More Solid Axle Swap Stuff
Old May 5, 2003 | 11:23 AM
FordPerf300's Avatar
FordPerf300
Some questions.
I have heard that the drag-link off a 92 F350 with the solid axle could be used. I imagine because the steering gearbox is inside the frame rail needing a shorter drag link. Anyone know the truth in this?
Also, thinking of using a trac-arm bracket off a similar year F350 truck with the solid axle, and an adjustable trac-arm, unless i really need a drop trac-arm bracket. Any info on that would be great.
This swap is comming down to the wire, just polising over some of the rough spots and the swap will begin.
