Pitman Arm Removal?
Old 05-24-2012, 01:37 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
Pitman Arm Removal?
Is there an easier way to get this off? I got the biggest pitman arm puller oreilly's had but it is to small. Do I need to get the separator style one?
Can I just use a pulley puller?
Old 05-24-2012, 01:46 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
I used lots of PB Blaster and a gear puller.
Btw, the installation torque for its nut is like 200 ft.lbs. I marked mine with a bright yellow paint line cuz it came loose a couple of times. Whoa.
Old 05-24-2012, 01:53 PM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Yes, whatever works best. I had one that I bought at AZ some years ago that was too big when I did mine. I ended up buying a different, smaller one at NAPA. It was the next expensive one, I believe. I also have the separator style one.
Old 05-24-2012, 03:20 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,363 Likes on 2,501 Posts
4" 3 arm gear puller and PB blaster it for a while, torque it (the puller) down and tap around the edge with a punch. Not to crazy so you do not jack a output seal.
A 3 arm gives a more even pull, and do not get under it cause it will come off with a bang ='s ouch.
Also can maybe get a pickle fork in there? For ah....motivation.
Old 05-24-2012, 09:15 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
Well we got if off with a air hammer. One little hit on each side and it came right off. Now with the steering box replaced I can keep it in the middle of my lane. Guess I will have to torque it a little more.
Old 05-25-2012, 07:27 AM
Grubbworm's Avatar
Grubbworm
Good for you. Sometimes it's easier than others. Sometimes you just have to walk away for a while, and come back to it later, with a fresh mind.
Old 05-25-2012, 11:56 AM
crazy96863's Avatar
crazy96863
crazy96863 is offline
Turn the wheel so the arm sticks out and a few whacks with a 4lb sledge. PB Blaster never hurts.
jerryst
11-15-2016 09:10 PM
DaytonaTunnel
08-18-2014 10:28 PM
flypfi
08-08-2013 11:03 PM
ichabod40
06-21-2010 09:31 PM
mrdavidkendall
12-29-2004 05:46 PM
Quick Reply: Pitman Arm Removal?
