460 swap questions
Old Sep 30, 2002 | 09:25 PM
Quantrex's Avatar
Quantrex
460 swap questions
I've found a very straight early '90's truck (F150?)with a totally wasted EFI 5.0 and an automatic. Just for the sake of curiousity, what am I looking at needing if I wanted to install a '77 460 and C6?
Old Oct 2, 2002 | 12:38 AM
Pilgrim's Avatar
Pilgrim
460 swap questions
The answer depends on a few things but here goes. Ask again if you need more info. I'll try to help. You will need: tranny, motor mounts, radiator, and some combination of things for hooking all this up. For example, fuel line(s), linkages, exhaust, hoses, ps pump, air cond pump, alternator, etc.. You may also need to change the length of your driveshaft. I swapped a 460/C6 into an 83 F100 that originally had a 300-6 and auto overdrive if you're wondering where I got my info.
Old Oct 3, 2002 | 03:16 PM
outkastzz's Avatar
outkastzz
460 swap questions
i would like more information. thanks outkastzz(No Email Addresses In Posts!)
Old Oct 4, 2002 | 02:21 PM
Redneckerson's Avatar
Redneckerson
460 swap questions
Old Oct 5, 2002 | 09:41 AM
Pilgrim's Avatar
Pilgrim
460 swap questions
What other info would you like? If you'd rather, send your questions off the forum to: pilgrimfarmsltd(No Email Addresses In Posts!) and I'll try and help you out.
Old Oct 5, 2002 | 09:55 AM
DeGideo's Avatar
DeGideo
460 swap questions
Since your're using a late-model truck,with a EFI engine,you must also swap fuel pumps.The EFI system's pump has too much pressure to work properly with a carbed engine.
