trouble codes
Old Oct 5, 2002 | 07:05 PM
4drbrnko's Avatar
4drbrnko
trouble codes
Old Oct 5, 2002 | 07:42 PM
mike_v2v98's Avatar
mike_v2v98
trouble codes
my f150 5.0 has been runnign kinda lame latley
so i decided to get the codes
key on engine off
539-- got this 2 times in a row but no meaning for it in the book
539
327--EVP or DPFE circuit below minimum voltage
332--insuficient EGR flow detected
334--EGR closed voltage higher then expected
556-- fuel pump primary circuit failure
539 does not exist in my book
when i did the test key on engine running i got
411--cannot control rpmduring KOER low rpm check
538--insufficient rpm change during koer dynamic response test
and it would not stay at a constant idle
my question is do these codes seem right and what is the 539 code for
also im trying to make light of these codes
i am guessing my egr valve is hooped
evp or dpfe circuit and fuel pump primary circuit i am baffled about
can anyone make light of this
Old Oct 5, 2002 | 07:50 PM
enrique's Avatar
enrique
trouble codes
I got that code 539 is "system shows voltage at PCM pin 10. Is A/C on"
I do not know if this means something to you
I also run EEC -IV codes and I am getting 542 which is "fuel pump open, bad ground or always on.
My problem is how do I fix it.... any ideas?????
Old Oct 5, 2002 | 08:01 PM
mike_v2v98's Avatar
mike_v2v98
trouble codes
i was wondering about that 539 code
i had my heater on
ive been told when the heater is on the ac pump runs
maybe that is what the 539 is from
