Injector issue?
Old May 23, 2012 | 10:18 PM
Hunterisdavid's Avatar
Hunterisdavid
Injector issue?
I have a 2004 PSD (6.0). 145,??? miles. I am getting a "cylinder contribution balance" on cylinders "6" and "8". Could this be anything other than injectors? If so, what? I haven't replaced them yet but was asking before i dropped that much $$$ into it.
Old May 23, 2012 | 11:27 PM
KRDiesel's Avatar
KRDiesel
You can also have a weak FICM, or a bad harness, I would check those 1st
Old May 24, 2012 | 08:12 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Follow this procedure:
https://www.ford-trucks.com/forums/8...procedure.html
Old May 24, 2012 | 07:05 PM
Hunterisdavid
FICM was replaced in January it died completely and left me stranded.
Should I still check it?
Bad Harness!? How would I check that? Couldn't just be a pesky faulty sensor?
Old May 24, 2012 | 09:47 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old May 24, 2012 | 10:22 PM
KRDiesel's Avatar
KRDiesel
In the tech folder there is info on "wire chafing" go over that. I just replaced #6, Took about 3 hours, so it is not bad.
Well 4 hours but I do not count beer run time :0
Old May 25, 2012 | 09:58 AM
Hunterisdavid
You replaced #6 injector? I am't worried about labor I'm worried about $400 injectors haha
Old May 25, 2012 | 02:15 PM
zhilton's Avatar
zhilton
$400 injectors? Where in the world are you buying them at? Through Tousley they're only $220...not that it's cheap; but they're not $400 either.
Old May 25, 2012 | 03:27 PM
KRDiesel's Avatar
KRDiesel
I get Bostech for $175 with a 75 core.
Old May 25, 2012 | 09:26 PM
Hunterisdavid
From Ford. They are like 360 but they want my core. W/ out giving them the core it was a few dollars short of $400. By the time I sPend fuel to the valley then climb the mountains back home I will have over $400 in them. Each. I may take my chances on eBay if that ends uP being the problem. And opinions on eBay parts?
Old May 25, 2012 | 09:40 PM
KRDiesel's Avatar
KRDiesel
no ebay parts for me. You can find good deals from the forum sponsors. That way is you have an issue you know that they will make it right. You will be in it for less than $400 for a quality rebuild.
This is the place i got mine from. They are in South Carolina.
Fuel Injectors – Diesel Injectors – Injector Pumps | ShopInjectors.com
Old May 25, 2012 | 09:42 PM
BLADE35's Avatar
BLADE35
Everone has had best luck with OEM Injectors
Try Tousley Ford Still around 400.00 with core but only 220.00 once the core charge is refunded
Tousley Ford Parts Depot
<TABLE border=0 cellSpacing=0 cellPadding=5 width="100%" align=center><TBODY><TR><TD rowSpan=2>FUEL INJECTOR F350; 6.0L Diesel; From 9/22/03
</TD><TD width=80 align=center>MSRP</TD><TD width=80 align=center>Core ?</TD><TD width=100 noWrap align=center>Online Price</TD></TR><TR><TD width=80 align=center>$266.67</TD><TD width=80 align=center>$180.00</TD><TD width=100 align=center>$220.00</TD></TR></TBODY></TABLE>
Old May 25, 2012 | 09:48 PM
BLADE35's Avatar
BLADE35
Wow 180.00 for a Injector Great Plus it had the Oring seal kit with it
Is this company a FTE Sponser???
KRDiesel's Avatar
KRDiesel
humm, If i knew that before I would have bought the ford injector
Old May 26, 2012 | 11:56 AM
zhilton's Avatar
zhilton
I'm not saying I'd never put their injectors in my truck...but something just seems too good to be true. Also, they list the 4.5L as an option in the Excursion and F250 through F650 (2003-2007)....never heard of that engine; just the 5.4L & 6.8L (both gas) and the 6.0L for the SuperDuties & Excursions. I know there has been the rumored 4.4L for years...but I didn't think that engine made it to production. Thus I question what kind of product they're putting out if they're listing an engine wasn't offered...or at least here in the states.
I don't think so, but then there are a few sponsors on here that I've never heard of.
