What kind of oil are y'all running ? I have not had a gas truck in 18 years so I'm starting over here .
Edit: Welcome to FTE.
Might be helpful to know which engine you have & what your drive cycle & regional operating temp range is, as not all of Fords engines are back speced to use 5W-20 viscosity, for good reasons.
I've used regular mineral grade Havoline for way over 50 years, that meets or exceeds Fords specified crankcase lube specs for my engines. Generally changed twice yearly/6 month interval, as most of my drive cycles are short term urban/suburban 10 miles or less. I use the specified Motorcraft oil & air filters, as they are of good quality, easy to come by, reasonable cost & thus a good bang for the buck.
All that said, if you aren't using Motorcraft oil, lots of good quality crankcase lube out there now, so choose one that states on its container that it meets or exceeds Fords specifications for your engine & type service the engine will see during the OCI & change it as specified in your owners manual for that type of service.
If your still in doubt, have an oil analisis done at the end of your OCI, to see how your crankcase lube, oil & air filter product choices are doing, the way your working them.
I have the 2.3 liter . I drive it bout 75 miles round trip to and from work . Live in south Texas with plenty of heat.
OK, good feedback, the 2.3L 4banger IS specified by Ford to use Motorcraft 5W-20 & its of good quality & can take the heat & road service with no problems where you live.
If you use another brand crankcase lube, make sure it says on the container that its licensed to meet or exceed Fords 5W-20 specs & you'd be good to go.
The Ranger 4.0L & some other Ford engines were never back specified to use 5W-20, as the 4.0L is to only use 5W-30, because its oil pump was never up graded to be able to pump the lower viscosity hot 5w-20wt, so the 4.0L would suffer delivery volume problems at operating temp & thats why I was asking which engine your Ranger had & where you lived.
The Rangers 2.3, 2.5 & 3.0L Vulcan were specified to use 5w-20, so thats the viscosity range you'll want to use.
Thanks for that info!!! I had no idea, and I'm getting ready to do an oil change this weekend. Wonder if using the 5W20 instead of the 5W30 will get me a little bit better gas mileage?
Don't know the hot viscosity of the lube you've been using, but
Ford says 0.6 mpg improvement by using 5W-20. That figure would be difficult for most of us to be able to measure, but fleet wide, with high fuel prices, it would add up to significant $$ & fuel consumption savings over time.
I know Ford has back spec'd 20wt. oil in a lot of their engines. But, I'm not sure I would be comfortable using it in an engine that has over a 150,000 miles. It may be fine with no problems. But, going thinner on a high mileage engine may not be the best option for protection.
^ not necessarily true because 5w 20 is thinner than 5w 30, so it can theoretically lubricate the smaller engine parts that otherwise a 5w 30 oil couldn't. I have heard many a debate about switching back-and-forth between 5w 30 and 5w 20 or changing weight out of the blue after a particular weight has been used for so long, such as 150,000 miles. All I can say is to use what the vehicle calls for. I have owned/leased 5 rangers since 97', and I have always had the shops put in what was called for. My 08' 3.0Liter takes 5w 20, and one shop used 5w-30 once in winter during an "oil change special" where it wasn't advertised that that was the bulk weight oil to be used. I felt that the vehicle performed pretty much the same -- it did seem a little ruffer on higher RPM's. Anyway, it doesn't get extremely cold here in Ohio like Wisconsin, Minn., or Alaska, so I kept it in for 3,000 miles instead of my usual 4,000/4,500. Did I do damage? Probably not. Would I take the chance again? No. Almost every receipt I have kept since my first oil change says 5w 20 weight was used, which is exactly what my vehicle calls for. I now have shy of 65,000 miles, and my Ranger still rides pretty darn well.
