Trouble starting when hot
Old May 23, 2012 | 04:07 PM
1991 F Super Duty's Avatar
1991 F Super Duty
I have been a member here for a while but I had to reregister, because the computer locked me out.
I own a 1991 F-Super Duty, 7.3 IDI, Over the last month or so I have developed a problem with the truck. When the engine is warm, the truck takes forever to fire. Truck acts like it's getting fuel or is fuel starved, but only when hot. truck starts normally when engine is cold, glow plugs come on, WTS light works fine.
I have good fuel pressure at the fuel filter, I know this because I pressed the schrader valve while it was being cranked and there was plenty of pressure.
The truck has had new injectors, MotorCraft Beru glow plugs, Glow plug controller just replaced two weeks ago to trouble shoot the problem.
I have never replaced the IP since I've owned the truck, I have no idea when the last time it was replaced.
Could it be one of the two switches or solenoids, what ever they are, on the IP?
Or possibly just be a IP that's tired.
If the truck sits long enough to cool down, the GPC will come on and the truck will start right up.
Hope this helps
Old May 23, 2012 | 08:42 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
when the internal tolerances (of something,i never remember,and never look it back up for lack of interest lol) in the ip ware,this can happen.
to test it,next time this happens,pour a little lukewarm to mildly cool water over the ip.if she then fires right up,then you know for sure the ip needs to be swapped out.
ideally these engines need an ip and injector swap every 100k miles anyway.
89ford460wrecker
Oct 17, 2017 08:42 PM
eutecticpt
42
Jun 24, 2016 07:47 PM
kpwall
13
May 12, 2012 09:36 PM
bfd_freddie
Sep 28, 2009 03:04 PM
old75F-100
Aug 16, 2006 08:15 PM
