1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
how do I remove my spare tire
Old 05-22-2012, 04:05 PM
deck60's Avatar
deck60
deck60 is offline
ok on a 2000 sd what tool do you use to remove the spare tire from under the bed looks like a torx or something like that any one know?????
Old 05-22-2012, 04:19 PM
kas83's Avatar
kas83
kas83 is offline
The 'key' for it should be in the glovebox. If not, don't know what to tell ya.
Old 05-22-2012, 04:20 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Here you go. (see attached)
If your truck has a lock in the winch, then you will need the key.
If you don't have the key then a 9/16" socket on some extensions will work.
File Type: pdf
Pushdeck1
19
05-12-2021 05:36 PM
Amish Ford
02-08-2016 07:04 PM
rvpuller
1997 - 2003 F150
09-15-2015 01:10 PM
indebt
13
02-18-2009 02:40 PM
glantineman
1997 - 2003 F150
02-08-2004 09:18 PM
Quick Reply: how do I remove my spare tire
