how do I remove my spare tire
ok on a 2000 sd what tool do you use to remove the spare tire from under the bed looks like a torx or something like that any one know?????:-X19
The 'key' for it should be in the glovebox. If not, don't know what to tell ya.
1 Attachment(s)
Here you go. (see attached)
If your truck has a lock in the winch, then you will need the key. If you don't have the key then a 9/16" socket on some extensions will work. |
