where to find molding set????
Old May 22, 2012 | 07:52 AM
85 ford's Avatar
85 ford
Looking to replace my moldings on my 85 shortbed. Anyone know where I can find a complet set???
Old May 22, 2012 | 08:05 AM
LARIAT 85's Avatar
LARIAT 85
Does it look like this?
If this is what you want, you are not going to be able to find it new. This style of moulding was only available from 1985 - 1986. Ford stopped making it about 12 years ago, there isn't any left over in the dealers across the country, and nobody reproduces it.
I think this moulding and the 1985 - 1986 aluminum tailgate panel are the only mouldings that are not avaialble for the 1980 - 1986 trucks.
Old May 22, 2012 | 08:12 AM
85 ford's Avatar
85 ford
Yeah that's what mine has but its perty much shoot, so I was thinkig of replacing it with the other style trim.
Old May 22, 2012 | 08:16 AM
CountryBumkin's Avatar
CountryBumkin
Two best places I have found for original equipment (new old stock, NOS) is
Greens Sales Company (but you need a part number to plug in)
Green Sales Company - Obsolete Ford parts, Lincoln, Mercury parts Green Sales Company, supplier of obsolete Ford parts and Lincoln / Mercury parts. Our Ford parts inventory represents all Ford and Lincoln / Mercury products from 1950 to the present.
and
Dennis Carpenter Restorations.
Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
Old May 22, 2012 | 11:10 AM
85 ford's Avatar
85 ford
Ill check it out to see if they have the complete set
Old May 22, 2012 | 12:14 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You won't be able to buy a complete set without buying each piece individually.
Even then there might be a few pieces that are rare and hold a premium price.
As Lariat 85 stated, you won't be able to find the 85/86 moulding new anywhere.
Good luck with your search.
Old May 22, 2012 | 06:49 PM
LARIAT 85's Avatar
LARIAT 85
If you are looking for the set on my truck that is in the picture, let me save you the trouble. The only pieces Green Sales has is the two short pieces that go behind the door. They have none of the other pieces. And Dennis Carpenter only has the left-hand side door moulding, the version with the extra cut-out for the swing-lock mirror cut-outs.
The other lower style moulding that was used from 1982 - 1986 is available from Dennis Carpenter. They have all of the pieces, but prepare to pay a pretty penny for the whole set. And unlike the 1985 - 1986 upper trim that used adhesive, the lower moulding is attached with clips and rivets, which means you will have to drill holes into the body.
Old May 22, 2012 | 11:08 PM
85 ford's Avatar
85 ford
Yeah I know that the whole set will be expensive but in my opinion its worth it in restoring my truck. And since I the upper is not available drilling the holes its not a problem. Ill give them a call in the morning to get a price.
Thanks
Old May 24, 2012 | 04:48 PM
85 ford's Avatar
85 ford
Found the comple set of moldings at a local wrecking yard for $125.
Old May 24, 2012 | 06:09 PM
CountryBumkin
If your wreaking yard has a complete truck - consider yourself lucky and start stripping it down. Door panels, dash pad, window motors, etc., - anything left that is in good condtion, because it is getting hard to find trucks for parts when they hit 25+ years old.
Old May 24, 2012 | 06:38 PM
85 ford's Avatar
85 ford
Yeah going to get as many parts as I can
Jghake
Mar 24, 2019 08:50 AM
Bootlegger's Deluxe
Jul 18, 2017 06:36 AM
Bird-Dog 250
Sep 21, 2015 08:12 PM
RussellF150
Dec 8, 2013 09:02 PM
mixgashaulass
Mar 30, 2013 04:07 AM
