Just looking for inside tips on doing the rear main seal whith the engine in the truck, And Yes to those who will question are you sure its the main seal..Im sure I allready have the old one out, I know there is a special tool to install the seal, has anyone done it with out the tool & it didnt leak ?
I also hear you need to install it DRY, any tips would be helpfull
Thanks
well its almost like being out of the truck, I have all kinds of room with the tranny out, I just know theres a special kit for installing it and it runs 350 to 500 bones, Im not going to pay that for a one time use. it looks straight foward like any other seal..
Hows that stage two cam. Just noticed that in your sig. Seems like alot of HP with 160cc 100 over. Must be the cam. Can you tell its in there at idle etc.. Thanks,
Bonanza, havent realy had alot of time on the motor yet, after the build it had a virbration and ran rough, so after some diagonistic checks had to pull the motor after 150 miles of run time, had broken ring on #8 & #5 Crank was out of balance, after repairs and back running again rear main seal is leaking thats where Im at now, just pulled trans to replace seal,
I know Ziggie on here had the stage 1 of Matt's and really liked it. He said he got 20mpg. He's a good guy, but I'd kill for that.
Man when it rains it ours, sorry to here about the rings. Any special brand not to use here. Guys have put there rear main seals in without the tool, its just not a common
leak area.
Ok did the rear main seal replacement with no special tools, I did make a seal install tool but it's nothing like the $400 dollar one. Finished the project tonight, no leaks. But don't think it's a easy job, the trans with the transfer case is heavy and is 54" long.
when i did my tranny replacement i used floor jack on transfer case and atv/motorcycle jack on transmission just let em down together and lift em together works slick for a 70 dollar atv jack
yep be sure to set up how your going to take out from under truck aka the dirction u face the jacks also mine just barley cleared on the jacks to come out by the running board area
Yes i have a cheap tranny jack from harbour frieght I had used only floor jacks to get it out but then went out and spent 140.00 for the tranny jack this allowed me to do it by myself, plus i have a lifted truck and needed the extra height even after lowering the truck.
