Left side 3.5" tapered block: Part #F81Z-5598-FA
Right side 3.5" tapered block Part #F81Z-5598-GA
If I had to do it all over again, I would save money and do the modded B's.
Stewart
Very good to know, I'll probably have to just do the front v's for now based on cost, however once the time comes around then I'll upgrade to the mod B's and the beefier 350 sway bar.
right now the V's and some new shocks will I think be enough for the 33.8" tires on 17's that I'm looking at. Hopefully I can finalize all this and get it done before I drive it to Nebraska at the end of June
Thanks so much for all your input and knowledge guys
If you do just the fronts, you know your rake will be off, right? Your front end will be high, it'll look like crap.
Do you already have a rear sway bar? If not, just get the Hellwig. It's easier and cheaper than running around trying to source all the parts just so you can use the 250/350 sway bar.
Stewart
I already have the rear sway, you can see it partially in the pic.
and ya in my earlier post I shared that I have current measurements (with 285's) from the wheel wells:
front: 38.5"
rear: 40.75"
might look like it's nose high but, with an expected 1.5-1.75" like people are saying their getting, I think I'll be pretty level.
and I can always add a little psi to the rear bags if needed, I just run the current 5psi because if it goes lower then the little compressor automatically pumps it back up to 5
Good deal.
All I can say is that i'd be lost without my wrx. I couldn't imagine life without it.
The feeling is mutual. Getting into a good curve in the STi definitely changes your opinions on good cars. I took it to the mountains of NC to hit some mountain roads, and OMG so much fun. Had my wife car sick in a matter of 3 miles
