axle help? what do i have?
Old May 21, 2012 | 06:24 AM
zombiehunter's Avatar
zombiehunter
trying to find out what axle is in my 66 f 100, it looks huge and it looks like a dana to me. here is the vin# F10AP775565. truck was originally a 240L6 with a granny 4 speed.
Old May 21, 2012 | 03:45 PM
BarnieTrk's Avatar
BarnieTrk
zombiehunter,
The type of axle cannot be determined by the VIN.
The axle type can be determined by the axle code which is located on the Warranty Data Plate.
The plate is located below the driver's door latch on the door.
Provide the axle code on your data plate and someone here can de-code it for ya...
BarnieTrk
Old May 21, 2012 | 05:11 PM
thechief66's Avatar
thechief66
Also remember, it's had 46 years for somebody to change the axle!
If you can post a pic it would help.
Old May 21, 2012 | 06:35 PM
critterf1's Avatar
critterf1
Picture, picture, picture.
Old May 21, 2012 | 07:10 PM
zombiehunter
ok ok... pics
Old May 21, 2012 | 07:56 PM
critterf1's Avatar
critterf1
Looks like a 44. Shortbed truck?
Old May 21, 2012 | 08:07 PM
kjvforme's Avatar
kjvforme
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=2 width=483><TBODY><TR><TD height=16 colSpan=6>
A9 = Spicer (Dana) 60.2 / 3.54-1 / LIMITED SLIP / 3300 lb Axle Capacity / 5 Lug Wheels; 5.50 Bolt Circle
</TD></TR></TBODY></TABLE>
129" WB would make it a long bed.
Old May 21, 2012 | 08:10 PM
Bill W's Avatar
Bill W
129 inch WB = long bed
Old May 21, 2012 | 08:42 PM
zombiehunter
so spicer (dana) 60, sweet. i think. anyone know any pros or cons of this behemoth? i have an 8.8 with 3:73 and limited slip and also a 9" from a 67 t-bird, i have perches to change it over from coil to fit leafs. are either of these a better choice. i should probably mention i yanked the 240 to rebuild for my supercharger, and im putting in a mild built roller 5.0L with a t10 toploader, hurst equipped. any input is greatly appreciated you guys are awesome.
Old May 21, 2012 | 08:52 PM
Bill W's Avatar
Bill W
Dana 60 point TWO. not just a dana 60... Very VERY hard to find parts for! sell all 3 of the rearends you have and find a correct 9 inch and bolt it right in. any 9 from a truck up to 1972 will fit like a glove
Old May 21, 2012 | 10:31 PM
zombiehunter
I kinda like the limited slip. We will see.
Old May 22, 2012 | 06:33 AM
zombiehunter
what spline count are the 9's from up to 1972? and anyone know the axle tube size.
Old May 22, 2012 | 07:51 AM
BarnieTrk's Avatar
BarnieTrk
As I recall, the axle spline count (in an up to '72) 9" truck differential would have been 28 spline.
31 spline axles came in SOME 9" truck diffs after '72.
Are you looking for the wall thickness, I.D. or O.D. of the actual tubing or the O.D. size of the bearing?
BarnieTrk
Old May 22, 2012 | 08:24 AM
zombiehunter
Thanks about the spline. I was curious of axle tube diameter for suspension purposes. Like for weld on link brackets.
Old May 22, 2012 | 08:53 AM
BarnieTrk's Avatar
BarnieTrk
A limited slip differential IS fun, but if you could turn it for a reasonable price, I'm thinking that a 9" would be stronger than the 8.8" and you'd have a wider selection of available parts (gears, axles, bearings, etc.) and maybe even have less $$ involved overall. Of course, you can always stick a limited slip differential in a 9"........ Just a thought.......
BarnieTrk
