Starting trouble for Flathead V8
I just have trouble getting it to start. I have put a new gas tank, gas line, fuel pump and have rebuilt the card. It seems like it does not get gas to the motor until it is running.
I would appreciate any tips or direction of things to check. Thanks
My '53 tractor has the same issues. I believe it vapor locks since the fuel line runs up and over the (bigger than stock) battery, going against gravity, like it should. But at the same time, I get an occasional non-fire, due to old wires being cracked.
I am no expert and it has been a lot of years since I've had anything to do with flat head V8s. I remember that some times the push rod between the cam and the fuel pump will wear and make it appear to have a weak fuel pump. As a temporary repair I have simply packed a small amount of tinfoil in the cup on the fuel pump arm (about an 1/8") to lengthen the push rod. I have also seen push rods that some one brazed the rod and ground it back to proper length. Of coarse this would only be temporary and a new push rod would be the way to go if this is your problem. Like some one else suggested take the gas line off and see if the pump is putting out enough gas or use a pressure gauge. If the pump seems weak look into the push rod thing.
Again I am no expert so hopefully some one with more expertise will come along with better advise. Good luck.
There are a couple of ways to check for this. One is to just pull the top off the carb after it has set for a day. If the bowl is empty, that's likely the issue. You could also take the fuel line off the carb after it has sat overnight and try to fill the carb with gas from a squeeze bottle. If it starts right up, there you go...
I appreciate the input and I will check these this weekend. I am leaning towards the power valve suggestions as I did use a new rebuild kit and it says that it is for a Holley 2100 or 94. I will give this a try. Does anyone know if you can get the power valve that is correct for a Holley 94?
If you go with replacing the fuel pump push rod as suggested by Old Ugly, you might find the following info of interest.
I recently got a fuel pump push rod from Dennis Carpenter on eBay. Mine had just over 3/32" wear after 30k miles, so I decided to replace it. It was for my late '49 239cu.
When it arrived I noticed the bag it came in said "Made in China". I've had some bad experience from "Made in China" before, but figured Dennis Carpenter would not risk their good name if it were not a quality part tested by them to protect not just their good name, but their loyal customers.
I installed it, fired up the engine and could tell immediately that something was wrong. After 4 or 5 minutes of rough idling, it died. I could tell something grabbed the cam, it actually froze the cam on the rise of the eccentric when it died. I pulled the pump, popped out the rod, and it was obviously not to spec. Just a few minutes of low idle showed wear from the cam, and I could see how it grabbed the cam when it died.
I contacted them with my complaint, and was told that they had sold 587 from this lot (Sept 2011 to the present) with no complaints yet. The fellow that knew the specs, Ron Harkey, was out of town till the following week, so I started calling around to other top name suppliers to get the spec on the push rod that they offer. Nobody I contacted could provide the specs. I even tried Little Dearborn and was told that they didn't have the specs, and even if they did they would not supply them, it was 'privy' info. This it ridicules, Henry Ford didn't hide specifications, he was proud of the quality. Now we have people promising the same (if not better) quality parts that are either hiding the numbers or just don't know them.
I was able to easily scratch the surface of the supposedly carbon-hardened cam end portion with a file. I then easily stamped the word CHEAP into it. As for appearance, they didn't even try to fake it, the whole rod looked like aluminum. Carbon hardened steel has a look to it, a slightly darker bluish tint that depends on the depth and quality of the hardening.
We ran it on the Rockwell hardness tester. You won't believe this. The cam end was tested in 2 places for accuracy. Rc-18 in one, and Rc-19 in the other. Should have been minimum 40 on the Rc.
I felt like I'd lost a friend in Dennis Carpenter, a good and trusted name, thinking they sold out to China along with so many other good names. They immediately refunded my money, no questions asked. I told them that they should notify all customers with push rods from that lot.
They just now got back to me with their findings on the investigation. Most of the rods they tested were way below spec, falling in the low to mid 20 range on the Rc, meaning their supplier in China was pulling a fast one. He said they should be about 50 Rc. He also said that the past two days were spent notifying their customers about it. I asked him about the other push rods, he said only the fuel pump push rod was made in China, and that they are thinking of making them locally now. Though I'm sorry this happened, I was happy to see how Dennis Carpenter responded, stepped up to the plate in (1.) acknowledging the problem, and (2.) taking steps to rectify it. This might have been a lesson to them as well.
I might put a webpage together with some images. If I do, I'll post back when it's ready. Take care, keep your eyes open out there.
Moosemunch
lAs a temporary repair I have simply packed a small amount of tinfoil in the cup on the fuel pump arm (about an 1/8") to lengthen the push rod. I have also seen push rods that some one brazed the rod and ground it back to proper length. Of coarse this would only be temporary and a new push rod would be the way to go if this is your problem. Like some one else suggested take the gas line off and see if the pump is putting out enough gas or use a pressure gauge. If the pump seems weak look into the push rod thing.
Moosemunch
