I bought a set of towing mirrors from an 05 the are power- heated and have the blinker in them
I am putting them in a 99 with no power anything
first problem the drivers side blinker is busted does any one know where I can get a new one from
second does any one have a wiring diagram for the mirrors
I know I will have to build my own harness i would like to use the factory mirror control switch and use a micro toggle for the extend and a relay for the heat
I'm about to do a set myself, and found my wiring diagrams in a Haynes repair manual at my store. Might not be the best, but tells you what you need to know. Good luck on the install!
A while back I was researching installing 2008+ mirrors on my 1999, and I came across this link. Maybe this will help, but I couldn't figure out how to get it to work as a link so you may have to copy and paste this into your browser.
