Speedo Cable Lube...
Old May 20, 2012 | 06:08 PM
CamTom12's Avatar
CamTom12
I tried to remove the cable from the sheath to clean/lube it and fix the metronome effect but I can't get it all apart.
I tried pulling from the Trasfer Case side first, then after that didn't work I tried separating the metal gear from the cable to pull through from the Speedo side, but I can't figure either of them. Right now I've got the cable completely disconnected from the Speedo and TC and that's as far as I can get in the process.
How's this supposed to work?
It's a '69 F-250 4x4.
Old May 21, 2012 | 09:57 PM
Freightrain's Avatar
Freightrain
Never saw one with a metal gear? Must be a 4x4 thing?
If you look closely at the speedo end, can you see a metal/nylon ring that keeps cable from pulling down through? Can you pull it up at all??
lavatan
Dec 29, 2011 12:53 PM
ErrorS
1978 - 1996 Big Bronco
Dec 2, 2011 10:37 AM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
64fordf100292
Sep 16, 2007 07:20 AM
redneckdieselmechanic
15
Jan 5, 2002 10:54 AM
