f250 thermostat
Old May 4, 2003 | 09:12 PM
cwhite's Avatar
cwhite
f250 thermostat
Help!
I can't locate the thermostat on my 1988 f250. I don't know why I am having trouble with such a simple procedure. The temperature gauge keeps climbing higher than normal, but eventually returns to it's normal reading so I am assuming the thermostat is getting stuck. I bought one, and I've disconnected each of the hoses on the radiator to look for the old one but can't find it. Any suggestions?
Old May 4, 2003 | 09:23 PM
c96drumm's Avatar
c96drumm
f250 thermostat
Follow the top radiator hose to where it goes into the engine. The hose should be attached to a fitting that's attached to the engine with a couple of bolts. Thermostat should be in there. At least that's where I've always found it.
