Interior face lift
Old May 19, 2012 | 04:45 PM
86bullnose's Avatar
86bullnose
Post Interior face lift
So I went to the junkyard today guys and I couldn't find good captain seats so I got a bench seat with lumbar support and an ARM rest. But the seat is beige and my interior is blue and the roof is that does grabber blue. The interior is blue like a darker blue. So I am going to respray the panels and get a new dash pad. But I am wondering how do i go about repainting the metal like the roof that has no panel and behind the pillars and below the rear windows? What color should I paint the interior? I am goin to get a tan seat cover and I want the color scheme dark blue and tan. Do I need to scuff the paint alittle or down to bare metal? Any suggestions is appreciated. I may have answered my own question but I would like your input thanks.
Old May 19, 2012 | 05:49 PM
ctubutis's Avatar
ctubutis
The best metal primer is the existing paint.
Old May 19, 2012 | 09:39 PM
1983F1503004x4's Avatar
1983F1503004x4
I don't really know much in the way of painting and body shops, but I would assume because the existing paint has already been primed, sealed, sanded, painted, and clear coated to seal the metal underneath, that it would function as primer for the new paint, right?
I would think that if you were to paint right over the existing paint you'd want to at least clean up the top coat of the existing paint? This would keep debris out of the new paint.
Maybe take some fine grit sandpaper and scuff the old paint and just go over the top?
Just thinking out loud.
Old May 19, 2012 | 10:14 PM
ctubutis's Avatar
ctubutis
Pretty much, yes.
The Paint & Bodywork forum here has got some pretty good info in its stickies.
Oh, of course! Existing paint doesn't at all alleviate the need for prep work. What I am more referring to is the preparation of the underlying metal has already been done
When I did my 1970 Mustang as a teenager, I bought a large toothpaste tube of a 3M product for filling in chips in paint. Don't at all remember its name and couldn't find it quick a quick Google search but it worked pretty well.
I learned, though, to leave that work to the professionals who know what they're doing.
Old May 19, 2012 | 10:34 PM
86bullnose's Avatar
86bullnose
So just going over the area a little with fine sandpaper should be good enough prep? Besides a clean surface of course.
Old May 19, 2012 | 10:49 PM
ctubutis's Avatar
ctubutis
I won't answer that at all as I am in no way a body repairman and am not at all qualified to answer stuff like that. To add to that, I did my Mustang about 30 years ago, I really don't remember the details of what I learned at the time.
Go look in the paint & bodywork forum and read the stickies, IIRC there's some good stuff there....
Old May 19, 2012 | 11:24 PM
Stangrcr1's Avatar
Stangrcr1
For good paint adhesion, you need to scuff the surface of the current paint to remove all gloss. Any chips, fill with spot putty and sand smooth. Once that is done, wipe it down with tack cloths and wax and grease remover. Tape off all that you don't want overspray on. Then paint.
Scuffing off all the gloss gets the old paint ready for new paint. If not scuffed, it will not stick very long.
Any auto body shop will have tack cloths and wax/grease remover. I recommend using it. Not using it will probably result in a bad paint job.
enrand
Aug 17, 2019 01:29 PM
HoustonGuy
Jan 29, 2011 09:57 PM
nbaff
Paint & Bodywork
Oct 14, 2004 10:40 AM
Pheonix BlackWolf
Paint & Bodywork
Oct 30, 2002 06:46 PM
jml
Garage & Workshop
Jun 29, 2002 10:31 PM
