Sponsored by: Real Truck
SuperDuty Tool Skid
Old May 17, 2012 | 01:57 PM
Blacksmith101's Avatar
Blacksmith101
SuperDuty Tool Skid
I have finally finished this project, and I thought some you you fine folks on here might find it interesting.
CPL Toolbox for hand tools, Delta with drawers for bench stock and long tools, 3 stage air compressor set for 150 psi, 12 and 24 volt jump system, lockable box with expanded metal top and bottom for cables, hoses, and large tools. CPL is mounted on drawer slides to pull out over the tail gate. The whole thing sits down over my goose neck ball to keep it from moving.
What do you guys think?
Old May 17, 2012 | 03:01 PM
bpounds's Avatar
bpounds
I like it. Some paint would be nice. What kind of work do you do?
Do you think those sockets might jump off the pegs when you hit some rough road?
Do you tend to work out of the truck daily, or will you use a lift to set this off at a worksite? Since you call it a skid, I thought you probably unload it frequently.
Old May 17, 2012 | 03:14 PM
jdadamsjr's Avatar
jdadamsjr
Jeeze !!!!
What a project - looks like you best work out of it everyday and make big money to justify all that fine work !
Nah, don't paint it - makes it look like you do WORK
Seems like it may be more than your payload all on the rear axle though !!!
Old May 17, 2012 | 03:25 PM
Blacksmith101
If every thing works out like I think it should, I will tear it down next winter and have it blasted and powder coated, but for now I will be using it raw.
The beauty of a CPL box is that when the lid is closed (and latched) it will prevent both the sockets and wrenches from coming off the pegs. I own a small trucking company and will use this rig for recovery/repair operations. We do ALL of our own repairs so you never know what you will need in the field. I also do custom combine and irrigation motor repairs in the growing and harvesting season, thus the need for a 24 volt jump start system.
The skid will live in the shed unless I have a job, as with the price of fuel it makes no since to haul it around when I don't need it. In fact, the reason I built it was because it was taking me an hour to load my pick up when I did need to go out on a call.
The thing is pretty heavy, more so than I had thought when I started building. Pretty sure I over-built the frame by quite a bit, but I managed to use only scrap that was around the farm from old projects or tear downs for the main frame.
Thanks for the compliments.
Old May 17, 2012 | 03:35 PM
bpounds's Avatar
bpounds
Originally Posted by Blacksmith101
...The skid will live in the shed unless I have a job, as with the price of fuel it makes no since to haul it around when I don't need it. In fact, the reason I built it was because it was taking me an hour to load my pick up when I did need to go out on a call.
That makes a lot of sense. What is in the steel box with diamond plate top?
Old May 17, 2012 | 04:44 PM
KRDiesel's Avatar
KRDiesel
nice work. rep given
Old May 18, 2012 | 10:45 AM
cpickner's Avatar
cpickner
Very nice job.
Reps sent.
Old May 18, 2012 | 11:29 AM
Blacksmith101
The large box actually has expanded metal for a top and bottom so sand and water can work right through. It is simply for lockable storage. Jumper cables, air hoses, grease gun, tow straps, pry bars, tire tools and hyd jack right now. Oh, and my big hammer, can't go out without my big hammer. :-)
Marten
Nov 1, 2018 07:33 PM
ExxWhy
Garage & Workshop
102
Dec 27, 2017 07:49 AM
duste
45
Feb 5, 2014 03:55 PM
nflfreak43
Garage & Workshop
20
Aug 20, 2012 09:01 PM
jniolon
56
Sep 21, 2008 09:15 AM
