transmission over heating
Old May 17, 2012 | 12:19 PM
sandgecko1's Avatar
sandgecko1
Just had it rebuilt installed 6 litre trans cooler but the trans gets hot after 40-50 miles of driving never got hot before pulling my 17k 5th wheel now pulling nothing it still gets hot what could it be also had a billet TQ installed
Old May 17, 2012 | 01:42 PM
Bonanza35's Avatar
Bonanza35
Who rebuilt the trans? Is the tork convertor locking up. If not it will get real hot quick. Did you put in a new 6.0L TC? Its not plugged is it. It shifts good and easy. I've never heard of a trans that ran hot because of a 6.0L TC. Mine runs extremly cool after the install.
Chet
Old May 17, 2012 | 01:51 PM
CSIPSD's Avatar
CSIPSD
Whats hot?
Old May 17, 2012 | 02:01 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by CSIPSD
Whats hot?
Kate Upton.
Stewart
Old May 17, 2012 | 02:09 PM
sandgecko1's Avatar
sandgecko1
Trans temp gets into the yellow and red not pulling anything my trans is a 4r100 with a 7.3 diesel
Old May 17, 2012 | 02:14 PM
CSIPSD's Avatar
CSIPSD
Factory gauge means crap. Get a real gauge and figure out what hot is.
Old May 17, 2012 | 02:23 PM
VegasFordSD's Avatar
VegasFordSD
FWIW, isn't he already waayyyy into the danger zone if he is getting up into the red on his factory gauge? Unless of course he has gauge failure with his factory.
I agree though, get yourself some gauges to monitor things and so these brilliant minds can give you better feedback.
Are you running any tunes, either custom or off the shelf... or are you all stock?
Old May 17, 2012 | 02:31 PM
sandgecko1's Avatar
sandgecko1
I have a bully dog tuner that's been on for a few years never had a trans temp problem before trans went out at around 149k had it rebuilt put 6 litre cooler same time trans went in and now can't figure out why the temp goes up after on the frwy 30 miles + could it be the fan clutch
Old May 17, 2012 | 02:34 PM
Bonanza35's Avatar
Bonanza35
No, on the fan clutch. Some poeple don't run them. Who was your builder of the trans? You need a real gauge is right. Did they take out the old 7.3 cooler as well?
Chet
Old May 17, 2012 | 02:44 PM
Stewart_H's Avatar
Stewart_H
What happened when your old trans "went out?"
What year is your rig?
Stewart
Old May 17, 2012 | 02:59 PM
sandgecko1's Avatar
sandgecko1
My rig is a 2003 the first time I lost 3&4 had it rebuilt and it lasted about a month it got hot and started slipping trans was rebuilt again and now it gets hot after around a half hour drive on the frwy usually not until I exit the frwy unless I start up a grade on the frwy 149k never had this problem no matter what I was pulling now I don't have to pull anything and it gets hot
Old May 17, 2012 | 03:02 PM
sandgecko1's Avatar
sandgecko1
Old cooler is out
Old May 17, 2012 | 05:37 PM
spezia's Avatar
spezia
i would check to make sure that the cooler bypass isnt bypassing the cooler, i have seen those go bad on other trucks causing same issue as yours.
Old May 17, 2012 | 05:48 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
How is the fluid level, and what does it look like and smell like?
Old May 17, 2012 | 06:16 PM
sandgecko1's Avatar
sandgecko1
The cooler bypass was removed by the rebuilder and the oil looks and smells clean not burned I took it back 2 times to the tranny shop 2nd time they said they put a new solinoid pack whitch has the temp sending unit in it
