I have a 92 F-250 2wd over 8500 GVW, and I have come across a set of rotors and dually adapters off a 89-91(not sure exactly) F-350, I looked up some of the bearings on autozones website and they have the same part numbers listed for a 92 F-250 over 8500 and the F-350, so my question is, will these adapter work with my spindles, and is there anything i'm missing to keep this from working on my truck?
Thanks in advance guys
Yea its the front, so the spindles are the same, just the rotors are different as long as i have the 8600+ GVW right? and the adapter is attached to the dually style rotor?
Well from my experience, I took a dually sterling and tried to put it into a truck that wasn't a dually originally, and realized that the frame on the dually truck was more narrow than the regular truck.
then you had the cab and chassis axle which is designed for a 34 inch frame width, regular duallys and 3/4 tons are 37 inches wide, roughly. the 34 is a commercial design so it can be adapted to any number of commercial beds like service beds, flatbeds etc.
