Differential Update
Old Sep 14, 2001 | 03:27 PM
MXZEric's Avatar
MXZEric
Differential Update
Old Oct 7, 2002 | 10:45 AM
Johncos's Avatar
Johncos
Differential Update
Well, I finally found the tag on my differential. According to the advice I got earlier,I have a limited slip diff. with 5.22 gears. Does that sound right? I read the numbers on the tag and it said 5L22. Somebody please help me clear up this mystery. Also, I am still not convinced I have limited slip, or if I do it isn't working anymore. Thanks for the help!
Old Oct 7, 2002 | 11:08 AM
honney's Avatar
honney
Differential Update
No, doesn't sound right except for the part about your l/s not working
Old Oct 7, 2002 | 11:28 AM
FordPerf300's Avatar
FordPerf300
Differential Update
[updated:LAST EDITED ON 07-Oct-02 AT 12:28 PM (EST)]Jack up the truck under the rear axle have someone watch the drive shaft and count how many times it rotates when someone else spins the passenger side tire once clockwise. Also, if it is LS, both tires will spin in the same direction when you spin one.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
