Mechanical Water Temp
Old May 4, 2003 | 03:56 PM
Dogman4324's Avatar
Dogman4324
Can someone tell me where I can hook up a mechanical water temp gauge on a 83 ford 460 truck motor. I would like to continue to use the electrical one and hook up and additional mechanical.
Thanks
Brian
Old May 4, 2003 | 06:48 PM
georgedavila's Avatar
georgedavila
Is there another plugged port on the intake? If so, use that.
Old May 4, 2003 | 10:13 PM
Dogman4324's Avatar
Dogman4324
I did not see one that is why I asked. Its has the stock ford manifold. I will check again but I did not see one.
Brian
Old May 5, 2003 | 11:30 AM
ZRX61's Avatar
ZRX61
Mine had one of the manifold & another on the thermostat housing.
Now I have the Performer intake I have 2 on the manifold & also 2 vacuum ports.
Old May 5, 2003 | 12:32 PM
dave98's Avatar
dave98
Hey,
I just put mine in a few weeks ago on my 82 460. Looking in the engine compartment from the front it's on the intake manifold very close to the front on the right side. I removed my "accurate" factory one with the wire and installed my mechanical one.
Dave
Old May 5, 2003 | 02:03 PM
ClydeSDale's Avatar
ClydeSDale
Just back from the thermostat. I added the mechanical one in addition to the OEM unit. It's interesting to see just how much variation there is between them.
minkbigbird
Aug 15, 2013 03:26 PM
06truck ED
Aug 25, 2010 07:39 PM
dbill66
Nov 14, 2006 07:33 PM
lukedraper
1978 - 1996 Big Bronco
Aug 5, 2005 03:35 PM
