Still in shock
Old May 16, 2012 | 09:02 AM
hoytfan99's Avatar
hoytfan99
Still in shock
Just got home from getting everything for my first oil change.$80 for filters and $110 for rotella t6. Thank god this isnt my daily driver.
Old May 16, 2012 | 09:21 AM
mblanken881's Avatar
mblanken881
you spent enough for two oil changes.
Old May 16, 2012 | 09:42 AM
hoytfan99's Avatar
hoytfan99
where can u get filters cheaper.
Old May 16, 2012 | 09:48 AM
mblanken881
Old May 16, 2012 | 09:55 AM
phantomphixer's Avatar
phantomphixer
Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Way cheaper. I order 3 oil filters ($14 Racor) 1 fuel filter ($36 racor)set at a time. Good for 15K miles. Order double sets to offset shipping. Although shipping is reasonable. Air filter $46.
T6 Rotella at Wally World appx $22 a gal. Catch it on sale. Stock up.
Old May 16, 2012 | 03:45 PM
hoytfan99's Avatar
hoytfan99
thanks, those filters will save a lot.
Old May 16, 2012 | 04:10 PM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Will for sure get my fuel filters from there. At local NAPA store they were 90$ for upper an lower.
Old May 16, 2012 | 04:17 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I'm buying a bulk pack all at once next time. 6 oil filters, 3 sets of fuel filters, toilet paper roll, and an air filter, $250 plus shipping But I'll be set for 30k
Old May 16, 2012 | 04:29 PM
raptor131's Avatar
raptor131
Great find! 21.36 here
"rotella t6 5w40" - Walmart.com
Old May 16, 2012 | 05:14 PM
Mich6.0's Avatar
Mich6.0
Don't put those NAPA filters in there is no water wick sock on the bottom fuel filter allowing water to your fuel pump and injectors
Old May 16, 2012 | 05:31 PM
69cj's Avatar
69cj
OEM filters only for oil, fuel and air. Only use recommended fluids. If you don't the 6.0 will bite you in the a**. Napa doesn't cut it. Motorcraft, Racor, IH and Donaldson only.
Old May 17, 2012 | 02:51 AM
redstang50's Avatar
redstang50
What's your opinion on fram filters? those are the most easily available for me (walmart/O'reillys) for oil/air/fuel filters. what about mobil 1 oil filter?
Old May 17, 2012 | 06:31 AM
zhilton's Avatar
zhilton
The Fram oil filter (CH9549) is the Racor repackaged part...which is fine/acceptable. Just make sure it has the felt ring & patient numbers on the bottom. The Fram fuel filter, I've yet to see one...so I would say no. This is what the correct filters look like (notice the aquabloc membrane on the primary)
The downside to owning a modern high powered diesel engine is the cost of routine maintenance. I'd buy my filters through either dieselfiltersonline.com or RiffRaff. Both have the pretty much the same price for filters. I buy enough filters (oil, fuel & tranny) to go 60k miles when I order.
RiffRaff:
Riffraff Diesel: 6.0L Fuel Filter Set
Riffraff Diesel: OEM Lube / Oil filter
Diesel Filters Online:
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old May 17, 2012 | 07:27 AM
redstang50's Avatar
redstang50
RiffRaff:
Thanks for the info. I checked out dieselfiltersonline, those prices are incredible compared to buying locally. I'm going to start stocking up like you said, that sounds like a good idea.
Old May 17, 2012 | 09:38 AM
fireman660r's Avatar
fireman660r
Wow that hurts. It costs me $80 for an oil change at the dealership. But my dealer has a program where every 4th oil change is free. We usually go through 3 $40 oil changes on the wifes car, then they give me my diesel change fo FREE. I am also friends with both techs and they give me the fuel filters for free left over from other jobs, slip them $20 and they change them for me. Not a bad day to get fuel and oil change for $20.
Force74
Oct 24, 2016 09:05 AM
RickF350
Nov 25, 2007 06:27 PM
Mikes95
2004 - 2008 F150
Jul 11, 2005 02:03 PM
BrianJ77
Oil & Lubrication
Aug 26, 2004 03:48 PM
ford390gashog
Oil & Lubrication
May 27, 2004 09:30 AM
