Doing a suspension upgrade through Cary at CT Performance
and need new tires. Considering 285 on current 16x7 stocks or
285 on new 18x9 (ATX Artillery) wheels.
Looking for thoughts from the tire & wheel guys.
There are those that say the X stability benefits from the
wider 9" rim. I also suspect there will be less sidewall
flex and maybe better wear pattern. The tires will be BF AT/Ko.
Many posters on here have put 285s on 7" wide 16" rims. Most tire websites do not recommend going that wide on 7" width rims. What aspect ratio are you looking at? 65 series? A lower aspect ratio (than stock 75) will probably improve the steering precision.
The factory option that was never delivered was the 18x8 wheels (like on 04 King Ranch F250), with 275-65/18. Michelin website recommends 7.5 - 9" rim width for the 275 mm width tire. For 285 mm width, they recommend 8 - 10" rim width, so your 9" selection is just right.
I have the 285`s on the factory X (XLT) wheels. they fit and look good. they wear great. however because I tow a heavy TT I will probably go back to the 265`s in the BFG Rugged Trail T/A or Commercial T/A Traction load range "E".
That makes me think I should just go with the 35s. If the 33s
Are only a little larger than stock I'll have some empty looking
wheel wells after the suspension upgrades.
