1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2000 Expy - Leaking rear differential
Old 05-15-2012, 08:19 AM
fred_79f250's Avatar
fred_79f250
fred_79f250 is offline
Gentlemen,
2000 Expedition, 4wd, 5.4l, auto, EB
Climbed underneath to double check my recent rear brake line replacement for leaks, and dang if the rear axle differential isn't leaking.
It's coming out the top - dripping down the face of the cover plate - last person in there sealed it with RTV and it's blown the seal at one of the upper bolts, so at least it stops leaking when stopped
I'll take a closer look, but pretty sure this is going to be a cover plate gasket replacement.
So, looks simple enough - remove cover, replace gasket, bolt cover back on, re-fill with fluid......except....darned if I can find a fill hole anywhere. Not on the cover, that's for sure. On the top of the diff housing there's an electrical connector that's bolted on the casing. Maybe under there? And what are those wires anyway?
Thanks.
Old 05-15-2012, 09:45 AM
pdqford's Avatar
pdqford
pdqford is offline
I doubt you will find a gasket for it. Just clean both surfaces with brake clean. Check each bolt hole in the cover to be sure non of them are dimpled from being over torqued. If they are, hammer them flat on a block of wood.
Put a thin bead of RTV all the way around the opening AND all the way around each bolt hole. Then let it cure for a half hour or so before re-assembling it. Sung it up in a criss-cross patern and then tighten to spec (33 lb-ft) with a torque wrench.
Check the vent line to be sure it isn't plugged or it'll end up pushing out a leak again.
Look on the left front side, slightly above where the DS connects to the diff.
On the top of the diff housing there's an electrical connector that's bolted on the casing. Maybe under there? And what are those wires anyway.
Rear axle speed sensor. Used by the ABS and the instrument cluster.
Old 05-15-2012, 11:37 AM
BAD RONALD's Avatar
BAD RONALD
BAD RONALD is offline
A new gasket was included with the new diff cover I got at Napa when I did my '01 a couple of months ago. I spent maybe 30 bucks.
Old 05-15-2012, 02:29 PM
fred_79f250
Yep - just picked one up - brand new gasket included. Nice.
Old 05-15-2012, 02:30 PM
fred_79f250
All very helpful. Thanks.
Old 05-20-2012, 04:16 PM
husky390's Avatar
husky390
husky390 is offline
You can buy just the gasket from Advance Auto Parts. Be sure to clean off all of the RTV on the pan and the diff. FWIW, I use RTV and a gasket. At $20 a bottle of gear oil, I want to make sure there are no leaks. I would also recommend buying a cheap hand pump from Harbor Freight. It'll make life easier when refilling the dif.
WilleyJoe.62
19
03-04-2014 07:44 PM
Firefighter 1406
1999 to 2016 Super Duty
08-14-2012 12:55 PM
Nitramjr
21
10-06-2009 09:44 AM
maxbm
Modular V10 (6.8l)
16
06-06-2005 06:23 PM
dclarson
1997 - 2003 F150
08-19-2003 08:17 AM
Quick Reply: 2000 Expy - Leaking rear differential
