Automatic Slow Engaging into Gear
Old May 14, 2012 | 05:55 AM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Lately when I go from park to drive or drive to reverse or reverse to drive it is a little longer than normal engaging into gear. Now we aren't talking minutes but like 3 seconds. The rebuild is about 4500 miles old. Is this something that could be normal or maybe a sign the filter is getting plugged? After in gear, it shifts and drives great!
Old May 14, 2012 | 07:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the filter is getting plugged it means the trans is totally trashed. Also, if the filter is plugging it won't shift and drive great.
3 seconds is on the high end of normal.
Old May 14, 2012 | 08:03 AM
robinsonpowerstroke
Ok so what are we looking fOr as the culprit, weak pump?
Old May 14, 2012 | 08:09 AM
grec-o-face's Avatar
grec-o-face
I'm interested in Marks response as well -- my trans seems slow to engage into R. Everything else is fine.
Old May 14, 2012 | 09:18 AM
Mark Kovalsky
Weak pump, leaky seals, nothing major. Two seconds is normal for this trans, so drawing the engagement all the way out to three seconds is only a one second difference. That's not much.
Slow engagements into reverse is a trademark of this transmission.
Old May 14, 2012 | 09:35 AM
robinsonpowerstroke
Ok well that makes me feel a little better. Cooler weather must be a normally longer cause she was slightly longer with it being 35 degrees this morning.
Old May 15, 2012 | 06:07 AM
FTMS's Avatar
FTMS
Mine is doing the same thing. Glad to hear it is normal.
n_boyd
Mar 5, 2020 11:31 AM
wfmcbride
Oct 22, 2018 06:14 PM
fletcher969
Oct 11, 2011 06:51 AM
joelswork
17
May 14, 2011 10:07 PM
patrickdemart
Apr 4, 2011 08:51 PM
