Oil buring?
Old May 4, 2003 | 08:58 AM
alpine's Avatar
alpine
Oil buring?
Ok I have a 84 f-150 with a 302. Latley it seems as if I might be buring oil. I have to add oil all the time. Now Ive looked everywhere on the truck and have found no leaks. The valve covers,oil pan, everything look fine. So I was wonder what kinda of a seal problem I might be having? Will I have to rebuilt the whole thing to stop it? By the way The engine is origanal and has only 60,000 miles on it. Im just getting sick of adding oil every week.
Thanks,
Alpine
Old May 4, 2003 | 02:46 PM
steve83's Avatar
steve83
Oil buring?
If you're actually burning oil, your spark plugs will show it. Pull them all & see. The Haynes manual shows how to read them. Another useful test (while you have all the plugs out) is a compression test. Use a threaded compression tester (not the press-in cheaPOS ) and block the throttle open for the whole test.
Old May 4, 2003 | 09:15 PM
Franklin2's Avatar
Franklin2
Oil buring?
A truck that old, with that low miles, must have been sitting around for some time. If you do find some of the plugs fouled, the rings may be stuck in those particular cylinders. You might be able to spray some penetrating fluid down the spark plug holes of those cylinders to try to free up the rings.
Old May 5, 2003 | 06:25 AM
alpine's Avatar
alpine
Oil buring?
Ya I got the truck from my father-in-law who had it sitting in a barn for 2 years. It was only drove about 6 times in the 2 years. Ill have to wait till it stops raining and pull the plugs to look. Thanks for the help guys.
Alpine
Amnfoxtrot
Jun 11, 2013 09:36 AM
duct tape F-150
19
May 4, 2011 12:37 AM
jjlrrw
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 16, 2007 10:25 PM
WiseMagic
Oil & Lubrication
Jan 19, 2007 01:06 PM
tealboy1
Jun 16, 2002 08:43 PM
