Transmission issue
Old May 13, 2012 | 04:32 AM
jimboniams's Avatar
jimboniams
Transmission issue
So basically the shifter on my truck will barely budge. With the clutch engaged or not the shifter just doesn't want to budge. It will go into first or second if you force it, but nothing else. I searched a bunch but couldn't find much.
I checked the fluid and its good.
I bled the hydraulic line for the master/slave cylinder and that didn't help.
My thought is the shift linkage could be broken?
Do I need a new transmission?
Any help/advice is appreciated.
Thanks.
Old May 13, 2012 | 08:36 AM
rla2005's Avatar
rla2005
What year/model/engine/transmission is your vehicle? That will help narrow down what the root cause may be.
Old May 13, 2012 | 04:04 PM
jimboniams's Avatar
jimboniams
Of course, can't believe I forgot this.
It's an 1989 Ford F150 Custom 2wd with the 4.9L 6 cylinder, not sure which transmission, it's a five speed manual with the concentric slave cylinder.
Sabgut
Jun 18, 2017 03:56 AM
1918ALF
Nov 15, 2014 02:10 PM
jhobbins
Sep 14, 2011 07:47 PM
TreoWayne
Mar 2, 2009 07:18 PM
wvanthony
Jan 25, 2002 09:49 PM
