anti-seize or not
Old May 12, 2012 | 11:17 PM
thomc's Avatar
thomc
anti-seize or not
I am working on getting my 56 back on the road.One of the things that I've done is swap the 472 Caddy engine for a fresh 472. I had to use the exhaust manifolds from the old engine on the "new" engine.In the process , I broke off 3 bolts that fasten the manifold to the head.I have drilled them out and cleaned the threads in all the holes. My question is...Should I use anti-seize on the new bolts? The breaking bolts must be a common problem on these Caddy engines as the 3 that I have owned all came with broken bolts and others I have seen were the same way.I have never used anti-seize on anything except sparkplugs in aluminum heads.I want the bolts to stay tight once installed , but don't want to experience any more broken bolts.They would be almost impossible to remove without having the fenders off and the engine jacked up. Thanks.
Old May 12, 2012 | 11:23 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
I wouldn't worry about putting anti-seize on them, after a few heat cycles it turns into more of a chalk than a grease. Just make sure you re-torque them after you run the motor for a bit and you'll do just fine.
Sam
Old May 13, 2012 | 07:13 AM
raytasch's Avatar
raytasch
Believe Nothing
Get the best quality manifold bolts you can find. I use anti-seize on all that stuff but hey, I am old school.
Old May 13, 2012 | 07:42 AM
oldmerc's Avatar
oldmerc
oldmerc
It won't hurt .The Loctite company make an anti seize that is rated for 2600 degrees .
Old May 13, 2012 | 10:11 AM
yamagrant's Avatar
yamagrant
Allan's right,It won't hurt. I put that **** on everything.
Old May 13, 2012 | 11:09 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Using studs and nuts might not be a bad idea, with copper-based antiseize on everything.
Old May 13, 2012 | 11:38 AM
CharlieLed's Avatar
CharlieLed
I use the Loctite red...hi temp...extensively. Your application is exactly what this product is made for.
Old May 14, 2012 | 11:18 AM
petemcl's Avatar
petemcl
Anti-seize
Metro Bolt & Fastener recommended that I use Dynatex. It won't wash out even with oil of gasoline. Good for SS bolts.
Knockonwood
May 17, 2019 02:51 PM
Si11ynood1er
Jun 29, 2012 04:32 AM
Frenchy
Nov 24, 2011 10:25 AM
fasthauler
Dec 29, 2006 11:49 PM
champdog
Oct 20, 2006 08:13 PM
