Modular V10 (6.8l)
2005 3 valve 6.8 Plug Change - Cracked Insulators
Old Jul 14, 2013 | 10:51 PM
Sven the elder's Avatar
Sven the elder
Thanks, tater.
I've been dreading my plug change also since I am nearing 80,000 miles.
Did the Kroil dissapate and you put more in after the first 1/8 turn? Or did it stay there till the second 1/8 turn? Glad you had good luck w/ the change!!
Thanks again, J
Old Jul 15, 2013 | 12:08 AM
truckfella's Avatar
truckfella
Thanks
FordCamping: I've poked around the V10 forum for many years now, and this is the first time I've read thru this thread. And while I have a 2v V10 and, thus, likely will never have to worry about this specific problem...I must give you a HUGE thanks for taking the time to post your pics, technique, experience, etc. These are the types of threads that are invaluable to other peeps on here!
Really well done. Kudos, man.
Old Jul 15, 2013 | 07:45 PM
tater_51's Avatar
tater_51
Originally Posted by Sven the elder
Thanks, tater.
Thanks again, J
I first filled up to the top of the hex on the plug and let it set (before even breaking them loose). I doubt that any of the Kroil wicked down but I just felt better doing it that way. After an hour or so I broke them loose, no more than a 1/8 turn. I let them set again for a couple hours and then turned them another 1/8 turn, filled back up to top of hex (only a little had worked it's way down) and let sit overnight. Next morning there was still Kroil sitting on the plug but I could see that some of it had worked it's way down the plug. When removing the plugs the carbon left on them was completely broken down and the plugs actually wiped clean with a swipe of a rag. I had one plug that was a little stubborn but once removed I could see that it had a lot of carbon build up. All the plug bottoms were wet where the Kroil had wicked down. I than used my shop vac with small hose attached and vacuumed the cylinders. Afterwards I spun the motor with all plugs removed before installing the new plugs. I choose a couple days when I knew I didn't need the truck and could take my time. Hope that wasn't too long winded, good luck!!
Old Jul 18, 2013 | 05:18 AM
JWA's Avatar
JWA
I too am not running a 3V motor however this thread is highly interesting, very very well done and just one great tutorial for these motors. Kudos and thanks for taking time to post this highly beneficial thread!
I will add most modular motors plugs should be changed at 50K miles which might reduce the seized-in-place plugs. While some disagree that nickel-based anti-seize is necessary or even advisable when properly used it too will help reduce problematic plugs during removal.
Reps sent to the OP for this thread-----highly deserved!
Old Aug 16, 2013 | 01:10 AM
hughjazz's Avatar
hughjazz
Fwiw, I did my plugs last year @ 120k miles.
I used an impact on the front 8, (small 18V makita) and I used a regular ratchet on the rear 2
with the impact, I just let the engine cool down enough to touch it, and whirled 7 of 8 out with no problems. (one broke.)
For the back 2 I did the whole ford TSB routine, and still broke both. (using the ratchet.)
I'm sold on the impact method personally. 1 broken in 8 isn't bad.
The lisle tool works great, Napa sells a clone set that works great too.
YMMV
interesting vid.
Ford 5.4 Liter 3 Valve Spark Plug Removal - YouTube
Old Aug 18, 2013 | 01:02 PM
Gage2502's Avatar
Gage2502
I dread this....I have about 30k on my truck and going to change the plugs this fall.
Thanks for the tips everyone.
...Gage
Old Sep 20, 2013 | 11:31 AM
buzter's Avatar
buzter
So what is everyone using for replacement plugs...Motorcraft SP515...Autolight HT2....other??
Old Sep 20, 2013 | 12:08 PM
JWA's Avatar
JWA
Its always recommended nothing but Motorcraft or Autolite equals in the modular motors.
The new 3 valve heads might change that however.
Old Sep 21, 2013 | 08:53 PM
FordCamping's Avatar
FordCamping
As you can see form my post here, I used the Motorcraft SP515 and have no regrets as of right now. The Autocraft option I "thought" was only single platinum where the Motorcraft was double.
I have come to grips with, don't be expecting 100K miles from these things. I was at 75K when I did mine and the next time, it may end up being 50K miles. Slowly over time you do not feel the degraded smoothness until you put new plugs ins and WOW This thing really does run smooth.
For sure make sure you use the nickel anti seize on the shield.
Good luck
John
Old Feb 26, 2014 | 12:29 PM
Thatrooper515's Avatar
Thatrooper515
Hey guys I have a 2008 6.8 v10. Just wondering what plugs I need? I'm going with motorcraft just not sure if I need the sp-515 or the 509s?
Old Feb 26, 2014 | 02:45 PM
dualwheels66's Avatar
dualwheels66
I think it depends on your build date.
Old Feb 26, 2014 | 02:55 PM
Thatrooper515
Yea..looks like I got the brown boots meaning I'll get the 509's. Anybody know what problem this plug removal will have? Hopefully it's straight foreword and no hiccups.
Old Feb 26, 2014 | 03:41 PM
  #28
doofuss's Avatar
doofuss
brown boots = one piece, no issues. You hit the V-10 loto!
Old Feb 27, 2014 | 09:45 AM
  #29
mudfuel06's Avatar
mudfuel06
I did mine about 20k ago and didn't have any problems other than no one in town stocked them. I got the motor up to operating temp, took the coils off, blew out the holes and took them out. I did put anti-sieze on the new plugs before they went back in.
Afrench67
Oct 21, 2018 08:45 AM
eveblack
Modular V8 (4.6L, 5.4L)
Jun 27, 2016 11:33 AM
DallasSuperCrew
2004 - 2008 F150
May 30, 2016 09:13 PM
tasboj
Mar 16, 2013 05:56 PM
