Wanted: 1948 Window Chrome
Old May 12, 2012 | 05:36 PM
BigBlueCat's Avatar
BigBlueCat
Looking for window chrome trim for my 1948 Ford pickup.
Old May 12, 2012 | 08:26 PM
needhelp49's Avatar
needhelp49
there is none
Old May 12, 2012 | 11:06 PM
51PanelMan's Avatar
51PanelMan
What do you mean by window chrome? Are you talking about the stainless steel trim that goes around the windshield, or the chrome wing window frames, or the stainless steel glass division bars....????
48-50s didn't have any of that from the factory or as an option. These were standard options in 51-52 5 Star Extra Cab (deluxe) trucks.
Old May 13, 2012 | 11:25 AM
BigBlueCat's Avatar
BigBlueCat
Re:Windshield Chrome Trim
51PanelMan,
I sent you a private thread earlier asking if windshield chrome from a 51/52 would fit. So, ignore it I guess. I just assumed that my 48 would have chrome. There are 4 clips that appear to be for attaching trim.
Old May 13, 2012 | 11:55 AM
51PanelMan's Avatar
51PanelMan
Sorry, I didn't see the profile message earlier.
Yes, the 51-52 trim will fit the 48-50 windshields. You'll need to buy new windshield weatherstripping with the provision for the trim. You'll need to cut off the four tabs that are in the windshield opening. If you don't do this, it will prevent the whole assembly to be installed and will break your glass. The trim need to be installed first into the weatherstripping, then the glass into the weatherstripping. Then the entire assembly gets installed into the opening in the cab.
No tabs for use with stainless trim.
Tabs for use without stainless trim.
There only one clip that holds the stainless trim together and it's at the bottom center of the trim. Make sure that the stainless trim has this clip.
$200 is about the going rate for a used trim.
LEDman
Dec 8, 2016 08:35 AM
proford1
Jan 21, 2010 10:36 AM
rwlacks
Oct 19, 2009 10:33 PM
68_F250
Oct 2, 2009 05:00 AM
51dueller
May 7, 2004 10:27 PM
