tachometer problems
Old May 12, 2012 | 03:40 PM
jeep_guy48's Avatar
jeep_guy48
tachometer problems
i blue the fuse a few time before it went out and i lost the tach. there is no light or tach when i replaced the fuse this last time but everything else works fine. i believe there is a sort in the cluster but want to check the wiring first before i buy a new cluster that i dont need. i have tasted the plug that hooks to the back of the cluster and pins 13 and 14 are the only ones that have power when it is running. does anyone have a wiring diagram or know or what circuit that i should be looking for??
Old May 12, 2012 | 05:41 PM
Talyn's Avatar
Talyn
Probably corrision on the contacts for the dash cluster, or burnt out lights.
Old May 12, 2012 | 09:44 PM
jeep_guy48's Avatar
jeep_guy48
while i had it apart today i changed a few bulbs and now i have light behind the tach but it still doesnt work. also there is no corrosion on the cluster it looks pretty clean. starting to believe that it is something in the wiring and not the cluster.
Handegard
Feb 22, 2014 11:27 AM
91 F-150 Farm Truck
Oct 25, 2007 12:36 AM
dhag911
20
Aug 3, 2005 01:04 AM
pikiluvi
Nov 23, 2003 06:30 PM
gimps
Bronco II
Oct 28, 2001 05:35 PM
