Help! reading the fleetguard strip
Old May 11, 2012 | 08:32 PM
jlwoods99's Avatar
jlwoods99
Okay, I bought this truck knowing nothing about SCA's and so on. I've learned alot thanks to you guys. I picked up some fleetguard test strips not knowing if he used SCA as he passed away and bought from his daughter. The way I read it was Glycol -45 So its good The Molybdate was row 2 about 300 ppm, the problem was the Nitrate It looked brown like the Molybdate until right at 75 seconds it changed and I called it row C around 550 ppm Nitrates. It bothered me that I didn't get a pinkish color until the test expired, was brown right to the end. I know this is long so thanks for reading if anyone can talk me thru this. So if I'm reading correctly I'm at 1.2Sca units per gallon. In my 92 F350 2whl dr. dually with auto trans.
Jim
Old May 11, 2012 | 08:50 PM
91dirtydiesel's Avatar
91dirtydiesel
Did u get this one?
Old May 11, 2012 | 09:05 PM
jlwoods99's Avatar
jlwoods99
Nope, It says fleetguard 3-way, its very similar and most colors are the same but it comes in a little envelope with a single strip. Mine doesn't test Ph like yours does. They were $1.59 each.
Jim
Old May 13, 2012 | 07:00 AM
fuzzy1626's Avatar
fuzzy1626
Your just in spec. Next oil change you'll have to add some. Did you check the use by date on the strip? When I first started useing strips I could find four strip packs that were good for a year. Now I'am lucky if I can find strips that are good for two months from the date of purchase.
I started useing all four strips on one sample and recheck my findings.
Old May 13, 2012 | 07:53 AM
whiteboyslo's Avatar
whiteboyslo
Where are you guys buying these? My local NAPA looked at me like I was a crazy person when I asked.
Mike
Old May 13, 2012 | 08:56 AM
fuzzy1626's Avatar
fuzzy1626
Mike
IH dealer or sometimes on line. If online I try to call first to ask for the use by date. Here's a link to one, but they are out of stock now.
Fleetguard Coolant Analysis Test Kit CC2602A | Wheeling Truck Center
Napa products are DCA-2
Ford and IH use DCA-4
IIRC, either one is fine but the strips don't interchange and the two should not be mixed mix.
Old May 13, 2012 | 02:03 PM
86sixbanger's Avatar
86sixbanger
Then how do you test for DCA-2?
Old May 13, 2012 | 02:07 PM
91dirtydiesel
Mike
Napa 4106.......says napa gold filter on it
JWA
Garage & Workshop
Jan 9, 2014 08:08 AM
Grubbworm
Dec 5, 2010 04:59 PM
ampslw
Apr 10, 2010 07:28 PM
Secret Agent 069
Feb 24, 2008 01:30 PM
Secret Agent 069
British Columbia
Feb 24, 2008 11:31 AM
