The other day somebody was leaning in my drivers window talking to me and spilled some pop. I thought that I got it all wiped up but today when I went to put my window down the button stuck. Any idea's on how to get it apart and clean it up?? Can it be done, what to clean it with, try to keep in mind I have yet to tear this truck apart. I guess you could say it was still a ...... Well I had better not say because of all the PREVERT'S runnin around here.
If you pop off the bezel or whatever then the switches pop off IN PAIRS. You will be able to clean it but only a little bit more then from the top. Just pull up on the bezel and it should come right off.
Just pull up firmly on front egde of cover plate to release retaining spring and pull setup back from door panel.You will see small tab in center of each wiring harness,push in tab while pulling back harness to relaese.Once you have harnesses removed you can remove window switch pod from cover by pring around edge where you see retention barbs.Then spray electrical contact cleaner(Krylon-available at any auto store) all around rocker swithes and use compressed air to dry.test and reassemble.Takes about 5-10 min
