How much 2 stroke
Old May 12, 2012 | 09:37 AM
  #31
Pitcrw6's Avatar
Pitcrw6
Yes, any 2 stroke will do.
Old May 13, 2012 | 10:05 AM
  #32
ToMang07's Avatar
ToMang07
NOT "ANY" 2-Stroke... you want "Ashless."
The Walmart "TC3" or whatever the Super Tech brand is about the best deal out there of Ashless 2-Cycle. That's what I run, 1oz/gallon.
Old May 13, 2012 | 10:21 AM
  #33
sloopdog1's Avatar
sloopdog1
The Wal Mart that I buy mine from keeps the small bottles of the 2 stroke oil on the display near the wall, the gallons are kept on the aisle display.Ask a clerk if they have it in small bottles if you cannot find them.Also if you use the gallon size, you will need a funnel, but the small bottles will fit into the trucks filler door quite well.
Old May 13, 2012 | 10:45 AM
  #34
Smokiesman's Avatar
Smokiesman
What I did when I bought the gallon jug was to use some clean 16 oz soda bottles and would store them behind my back seat! When I filled up just grabbed a bottle and poured it in!! No muss no fuss!!
Smokie
Old May 13, 2012 | 11:07 AM
  #35
RedBoat's Avatar
RedBoat
Rather Be Floatin
Smokie
Thats what my method was! But I only used it approx every other tank.
Old May 13, 2012 | 02:03 PM
  #36
Pitcrw6's Avatar
Pitcrw6
Well to be honest I haven't seen anything else but ashless at walmart in the auto section unless im going blind.
Old May 13, 2012 | 03:38 PM
  #37
CSIPSD's Avatar
CSIPSD
Just threw a gallon in the tank today!
Old May 13, 2012 | 09:49 PM
  #38
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My work carries "Lucas Semi-Synthetic Low Ash Smokeless"
Old May 13, 2012 | 09:54 PM
  #39
moontrain's Avatar
moontrain
Maybe I should be using more than I do. I only use 1 of the small bottles for a tank every other tank full ( 38 gals. ).
Old May 14, 2012 | 06:32 AM
  #40
microdevil45's Avatar
microdevil45
See you learn something new everyday. I thought DK was the norm and didn't even consider the 2 Stroke oil. Now not taking cost into consideration, what do you guys think of a 2 to1 mixture of 2 stroke and DK. For example 16 oz of 2 stroke and 8 oz of DK mixed in a bottle and used. Both offer different properties and could be a better over all usage (at least in my twisted mind)?
Sorry didn't mean to hijack just curious...
Old May 14, 2012 | 08:34 AM
  #41
CGMKCM's Avatar
CGMKCM
I remember reading that 1/2 to 1 ounce of TCW3 rated oil per gallon of diesel fuel was the recommended mixing ratio.
I tried 1/2 ounce and thought it worked well. I have not tried the 1 ounce per gallon ratio.
Old May 14, 2012 | 09:22 AM
  #42
Pitcrw6's Avatar
Pitcrw6
The 2 stroke is just for lubrication only and the DK helps with celtane boost and helps clean and keep you fuel system clean and lubrication and a couple other things. I dont see a problem running both at the same time.
Old May 14, 2012 | 09:53 AM
  #43
szotty's Avatar
szotty
i take and mix dk and 2 stroke half and half then pour the amount i want to use in to truck when filling up been working good for me winter or summer i just change the bottle of dk i buy
Old May 14, 2012 | 11:58 AM
  #44
microdevil45
Yep I think this is what I'm gonna start next fill up.
Old May 14, 2012 | 04:33 PM
  #45
PwerStroke99's Avatar
PwerStroke99
Just buy the gallon SuperTech 2 stroke oil at Walmart, about as good of a price as you will find. One quart per fill up for me. Definitely quiets my motor down
