How much 2 stroke
Old May 10, 2012 | 05:51 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I was looking on Amazon. They have some on there, I was looking as some 1 qt 12 packs, but they are like $50. Does that seem right? I'm new to the 2 stroke world, but the logic is sound to me.
Old May 10, 2012 | 05:59 PM
Pitcrw6's Avatar
Pitcrw6
To me that is way to high. Go to walmart and see whats they sell there cheapest for. Maybe the price went up because $$$ per barrel went up. I think I payed like 2 bucks a qt.
Old May 10, 2012 | 06:34 PM
That_Guy's Avatar
That_Guy
Whats the difference between using 2 stroke oil and diesel kleen? Does it offer any more benefits then DK?
Ive run DK for a long time now with no problems
Old May 10, 2012 | 06:37 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Price. 2 stroke lubricates Diesel Kleen cleans and boosts cetane also.
Old May 10, 2012 | 06:56 PM
hammer65's Avatar
hammer65
Walmart Super Tech. 1 Qt per fill up. usually around 25/28 gals
About $11.00 per gallon
Old May 10, 2012 | 07:31 PM
That_Guy's Avatar
That_Guy
I thought the DK also lubricates?
Old May 10, 2012 | 09:52 PM
smithrock's Avatar
smithrock
1 qt per fill up works. Any 2-stroke oil will work fine. Get what's cheap, your only using it for lubrication. I usually put a qt of unused hyd oil every other fill up.
Old May 10, 2012 | 10:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
It does. That's why I said "also" but I can see your confusion from my wording.
Old May 10, 2012 | 11:14 PM
Lying Larry's Avatar
Lying Larry
I would go light on the HYD oil as it has additives to stand higher preasures that won't burn. I had a problem with a lot of carbon build up around the holes on the injectors on a roller to the point that it would not pull the load. I am sure we had more HYD oil transfer than you are useing. I use walmart 2 cycle.
Old May 11, 2012 | 03:48 AM
Nsaan's Avatar
Nsaan
I am sure you can run much more than that if you wanted... I know of people that are running 50/50 used oil and diesel year round. In the summer they only run about 20% diesel, the other is either used oil or trans fluid....
I don't do it, maybe if I had to buy my own fuel it would be worth a try for me. I have used diesel klean before, frankly I didn't see or feel a difference, I do put it in my back storage tank to help keep it stabilized and good from time to time. I do it less often now as I fill both of my trucks out of the back tank and fill it up when the price is good to keep it rotated and good. I have let it sit up to a year with DK in it before, back when i only drove my cummins for 2k last year... i drive it more often now, like on weekends.
I guess you are using the 2 stroke more as a lubricity additive then as a fuel, I know the state of Az is cracking down on "illegal fuels" at the last training I was at they had signs up all over about it.... and how to turn people in. I just laughed and kept walking. To me it sounded like it was all about them not getting their cut of the fuel tax.
Motor Vehicle Division
Old May 11, 2012 | 06:06 AM
Superduty ROCKS's Avatar
Superduty ROCKS
Only 2 stroke Super Tech I could find in a gallon at Wally World was for outboards. Is this what you guys are using?
Old May 11, 2012 | 06:15 AM
hhcobra's Avatar
hhcobra
Yes. That is the correct 2 stroke.
Old May 11, 2012 | 10:21 AM
  #28
Smokiesman's Avatar
Smokiesman
Yup! Wally World 2 stroke ! I used the 1oz to 1gal and it sure quieted down my 99!! I am sure DK is a good product but I could really see no change using it?
Smokie
Old May 11, 2012 | 11:57 AM
  #29
That_Guy's Avatar
That_Guy
Yea I just wanted to make sure. Thanks.
Old May 11, 2012 | 08:55 PM
  #30
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Acceptable?
It was $3.99/qt. It was the cheapest other than a no name for the same price.
