running problem
Old May 9, 2012 | 09:35 PM
94-f-150 screwed's Avatar
94-f-150 screwed
running problem
my truck has a hard time starting once it does the idle and vacuum is normal if you give it any throttle it bogs out and wants to stall......while the engine is at 2000 rpm needle moves like it would for exaust restriction.....does it sound right
Old May 9, 2012 | 10:00 PM
DRRXR's Avatar
DRRXR
Whats the engine
My guess is that the MAF is dirty or the TB gasket is leaking. But I would think its the MAF unless you have a vacuum leak.
Quick test is the next time you start it un plug the MAF and the ECM/PCM what have you will go to default mode and then see if it does it acts up again. If its good then replace the MAF pull the batt cable for 10 minutes or so to reset the ECM/PCM and then hook it back up.
Test that and repost
Also has this been yours or did you just get it?
Old May 9, 2012 | 10:48 PM
ctubutis's Avatar
ctubutis
I would pull the codes, first thing.
Fuel Injection Technical Library » How To Run a Self-Test
Old May 10, 2012 | 11:34 AM
94-f-150 screwed
its been in the family for years butt its been sitting for 1 year
Old May 10, 2012 | 11:50 AM
94-f-150 screwed
it has the 300
Jayburna
Modular V8 (4.6L, 5.4L)
Apr 25, 2017 08:02 PM
wae
Jun 2, 2009 11:06 AM
carsrus
1983 - 2012 Ranger & B-Series
Feb 4, 2008 07:02 PM
jv42287
33
Apr 7, 2007 06:05 PM
rleptrone
3.8 & 4.2L V6
Jan 21, 2005 08:19 AM
