p007d code
Old May 9, 2012 | 09:22 PM
BigBear1's Avatar
BigBear1
Cool p007d code
I have been getting a P007D - Charge Air Cooler Temperature Sensor Circuit High (Bank 1) code for some time on my f-550 company service truck. When I actually had a spare moment I took it in to the dealership. They told me that the sensor was unplugged and charged me $132 to plug it back in , and a week later it came back on and has been turning on and off for months. Sometimes it will only build 20ish pounds of boost which gives it seriously low power. could someone tell me where this sensor is so I can "plug it back in" or replace it. the sensor is inexpensive and i dont have the time for it to sit at the dealership for a week and have them not fix the problem. thanks!
Old May 9, 2012 | 09:30 PM
darren32's Avatar
darren32
Here ya go boss.
Old Jan 19, 2015 | 07:09 PM
Ben B Stiltner's Avatar
Ben B Stiltner
Charge Air Cooler Temperature Sensor were is the location of this sensor
Old Jan 19, 2015 | 09:39 PM
Iowa Ford's Avatar
Iowa Ford
Ben, open the PDF, in post #2 above.
Looks like #9 to me.
Good luck.
Old Aug 25, 2021 | 08:06 AM
cooperm's Avatar
cooperm
Hello everyone. I know this is an old post. However I received this code P007D yesterday. I was able to locate the sensor. It was plugged in it appears to be tight. After further investigation. I traced the wired back and see that it runs down past the radiator. Here is the problem. The 2 wires were broke about 5 inches away from the connector. I was able to pull them back and remove the connector and splice the wires with connectors and a crimp. Not sure if that is a long term fix or not.
So the question is; Is that enough or do I need to trace the cable all the way back and replace the whole harness? I don't see the harness for sale on any sites, but do see the connector available.
Thanks,
Mark
Old Aug 25, 2021 | 08:56 AM
Fefanatic's Avatar
Fefanatic
If that cured the problem then you shouldn't need to go any farther. FWIW, I would go back in there and solder those wires. I would also locate the reason those wires were cut or broke and stop that from happening again.
Old Aug 25, 2021 | 09:00 AM
cooperm's Avatar
cooperm
Thank you for the quick response. I did relocate them away from the area where they broke. They are now tied up away and to something smooth. I can get to tehem pretty easy to solder.
Thank you.
Old Aug 26, 2021 | 05:03 PM
The Bone's Avatar
The Bone
Shrink wrap then as well. Don't just use electrical tape. A blow dryer will shrink the wrap or a lighter will do if you don't have a heat gun.
mebe2k
6.7L Power Stroke Diesel
36
Feb 18, 2021 12:57 PM
air1jpg
2004 - 2008 F150
Feb 19, 2014 09:22 PM
Georgeandkira
1997 - 2003 F150
Sep 19, 2013 10:08 AM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
dmanier
1978 - 1996 Big Bronco
Oct 27, 2002 04:46 PM
