Lift kit questions
Old May 9, 2012 | 08:24 PM
xc4jokestomper's Avatar
xc4jokestomper
Lift kit questions
Im going tomorrow to get a 6" lift kit from a guy near where i live for $300. its got skyjacker shocks and i think he told me it had sky jacker springs as well. im not sure what brand the brackets are. but anyways it just dawned on me that he was also sellig extended radius arms. i told him i didnt want them because he was wanting $200 more for them. my question is does the extended radius arms use the same drop brackets that the regular arms would use for a 6" lift? or am i going to have to go and buy the rad drop brackets?
also what all do i need to be sure and get from him?
-springs
-axle drop brackets
-radius arm brackets
-add a leaf/blocks/springs for the rear
-drop pitman arm
-radius drop brackets if avaliable?
-shocks
im not worried about the shocks if he doesnt have them or the extended brake lines. but am i forgetting anything else?
Old May 9, 2012 | 08:39 PM
BigBlueOx's Avatar
BigBlueOx
The extended rad arms use the stock brackets. The stock rad arms require drop rad arm brackets.
Old May 9, 2012 | 08:40 PM
xc4jokestomper
So I either pay $200 more for extended rad arms or $200+ for drop brackets. Hmmm I wonder lol
Old May 9, 2012 | 08:55 PM
BigBlueOx's Avatar
BigBlueOx
Haha. Yeah, go for the extended arms. The drop brackets create a weak spot in the suspension.
Old May 9, 2012 | 08:56 PM
xc4jokestomper
Will do. Assuming its a skyjacker kit, that's a $1600 kit.
Old May 9, 2012 | 09:20 PM
xc4jokestomper
What would be the best way to clean these parts up? Obviously sandblasting and powder coating would be best but what's my other options? Would a farm paint hold up pretty well? Maybe sand down, prime, farm paint, and then a clear coat?
Old May 9, 2012 | 09:57 PM
BigBlueOx's Avatar
BigBlueOx
I usually wire brush them completely with a wire wheel on a 4-1/2" grinder then hand paint on rustoleum paint. Rattle cans may look better but the brush on stuff lasts SO much longer.
Old May 9, 2012 | 09:59 PM
GNR22's Avatar
GNR22
I would just sand it down a little bit, then use some Rustoleum "stop rust" primer, and then paint over that whatever color you want it to be.
my91stealth
Dec 9, 2010 01:34 AM
dale gribble
Jan 26, 2006 02:54 PM
bsmotorsports
Dec 1, 2005 06:53 PM
moose94
Oct 1, 2004 04:54 PM
truckfreak69
Jan 20, 2003 01:49 PM
