74 F250 Starting problem
Old May 9, 2012 | 08:56 AM
Sean's 97 F250's Avatar
Sean's 97 F250
Have a 1974 Ford F250 with the 460ci motor, auto trans, and 4x4. This is the model with the tool boxes built into bed and it runs good (when it starts) and is in excellent shape. However it takes mad spells. Some days you can try to crank it and it starts, then sometimes it wont. Every now and again, it dies on you going down road. I have checked the coil and replaced, along with other firing items. What else could it be.
All Help Is Appreciated
Old May 10, 2012 | 10:11 AM
critterf1's Avatar
critterf1
I'd be checking all the grounds. Check for spark and fuel when it won't start.
Old May 10, 2012 | 12:32 PM
Sean's 97 F250
fire
It is getting fuel and fire just takes mad spells every couple days. I need to fix as for I use to haul my ride mower on when I mow yards. Thanks for info.
Old May 13, 2012 | 12:52 PM
82f100460's Avatar
82f100460
I would pull the codes off the OBDII as well as check all you connections as indicated above.
That computer might be telling you something
Edit: sorry about that...I was looking at your name (97 F250) when I wrote that....now I see you're talking about a 74
mastapasta
May 27, 2017 02:46 PM
1bluefarmtruck1
Dec 27, 2016 11:45 AM
Campbell 56
May 14, 2015 06:26 PM
tjones2269
Dec 4, 2009 01:00 PM
SasquatchF-250
Mar 12, 2005 05:41 PM
