Awesome forum!
Old May 9, 2012 | 08:08 AM
mmaks's Avatar
mmaks
Awesome forum!
Just a quick note of thanks to all the knowledgeable folks on this forum for help in fixing one of my troubles.
I didn't post, but did a search here on my jumping speedometer problem. When driving I noticed the speedo jumping wildly, usually whenever I hit a bump. It was so bad I thought the needle might break off. Occasionally it would not work at all.
Thru the advice found here I pulled the VSS and cleaned the small amount of gunk on it. Then the speedo didn't work at all, and the tranny would shift violently. While under the rear end, I did notice that the protective cover on the VSS wiring was a bit chewed up. So I removed a section of the covering and there it was--the two leads looked they got caught up in a rototiller! I don't know what happened to them as I had just picked this truck up a short while ago. But replacing about 14 inches of the two leads fixed the problem completely!! And to think I was originally looking for a speedometer cable issue--ha.
Now on to my tranny dipstick and rear fuel pump problems. Thanks again!
Old May 9, 2012 | 10:56 AM
rla2005's Avatar
rla2005
Thanks for posting your issue and resolution. Plenty of great info floating around on this forum!
sticks25
Nov 11, 2008 04:56 PM
cerberusdog
Mar 22, 2007 10:44 PM
imfixinmopars
Jul 2, 2006 07:29 PM
elvis on cape
Aug 15, 2005 07:06 PM
iceman06
Jun 6, 2005 06:38 AM
