302 engine swap
Old May 7, 2012 | 09:27 PM
wolfs86F100's Avatar
wolfs86F100
302 engine swap
ok guys here goes my 1st post on FTE,i have an 83 f100 302 cam bearings going out low oil press from what i understand up to 83 the engines were just regular engines as far as cams and lifters and all and in 84 ford went to the roller engine i am beginning to search used engines and something as old as the 83 havent been in too good of shape wil the roller engins run with my old stock ignition system ,mechanical fuel system or will there be many more sensors and ecms involved ? so far what few parts people i have talked to have no idea.....input please thanks
Old May 7, 2012 | 10:21 PM
Gary Lewis's Avatar
Gary Lewis
I don't think the roller engines started until much later, like '89 or so. I know for a fact that the '85 351HO's were still flat tappet.
Having said that, the lifters don't make much difference. Pull your engine and install the carb and all the various sensors on the new engine and away you go. But, if the new engine has a serpentine belt system you'll have to work a bit to make the connections there as the alternator will be different for sure.
Old May 7, 2012 | 11:19 PM
kedwinh's Avatar
kedwinh
Think your right Gary. I know my 84 Mustang didn't have the roller cam.
Old May 8, 2012 | 08:01 AM
noal133's Avatar
noal133
I found this on Wikipedia, " The block was fitted with revised, taller lifter bosses to accept roller lifters, and a steel camshaft in 1985"
Old May 8, 2012 | 08:09 AM
ctubutis's Avatar
ctubutis
Wikipedia has been known to be wrong before, or it could be talking about something else, or who knows. Providing only a quote snippet doesn't do us any good; what's the URL of that quote?
In any event, I agree with Gary & Kedwinh in that I believe the roller engine stuff didn't come about until, at the earliest, the late 1980s, and quite possibly the early '90s. I remember looking into this stuff when I rebuilt my engine a few years ago.
Old May 8, 2012 | 08:17 AM
Gary Lewis's Avatar
Gary Lewis
But in what vehicles? Anyway, it doesn't matter as you can still swap whatever induction hardware is on the current engine onto the new one. Do the same for exhaust, add on any other sensors, address the alternator issue if it has a serpentine belt, and it'll run - regardless of what type lifters and cam.
Old May 8, 2012 | 07:14 PM
bruno2's Avatar
bruno2
The 302's had roller variations at some point. The 351's may have been as well. I had to use retro fit roller lifters in my motor(351W) because it was beofre a certain yr. The roller lifters and roller rockers wont make a difference with any of the other external components. The ignition doesnt know if the motor has roller hardware or care.
Old May 8, 2012 | 08:52 PM
wolfs86F100
good deal thanks guys opens up some more options for replacements just dont have the cash right now to build the original which is what i would rather do but i wont do it unless i can do it RIGHT
gwhpnut
Mar 29, 2011 02:11 AM
gwhpnut
Jan 9, 2011 12:24 PM
jade79
Mar 7, 2004 06:12 AM
Pugo
Feb 9, 2004 11:53 AM
svt_god
Jan 28, 2004 08:45 AM
