Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Code P0446 and slow gas filling
Old May 7, 2012 | 04:36 PM
Jimmy Mills's Avatar
Jimmy Mills
I have had slow gas filling problems for a while now and recently had the check engine light come on and pulled code p0446. I located the vent hose in the back wheel well and it was clogged so I cleared debris from it and took the system apart and found some water in it so I cleaned everything out. I bench tested the vent valve to make sure it was working properly, it was. I put everything back together but am still getting the p0446 code and the tank still isn't filling properly. I know there is a purge valve in the engine bay, could it's malfunction be causing these problems? Any suggestions on what to check next?
Thanks in advance!
Old May 9, 2012 | 12:26 AM
martin_csr's Avatar
martin_csr
What Escape is it? I think there's a filler neck TSB or something on some models.
Old May 9, 2012 | 07:10 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by valdarrus
check engine light on means some fault codes stored in your car.
USB ELM327 V1.4 can help you clear the p0446.
_______________
better tomorrow!
He already read the code....
This is a duplicate of a thread from last month. Sounds like he didn't follow instructions in that one.
See PCED for diagnosing the DTC.
For the slow fill, see TSB 07-11-1 for a modification of the vent line on 05-08 Escapes.
Jimmy Mills
Apr 22, 2012 10:42 AM
pablocruz69
Aug 13, 2010 12:50 PM
Galveston Yankee
1997 - 2003 F150
Jul 11, 2009 08:13 PM
lazybones
General Automotive Discussion
Oct 8, 2004 08:07 AM
jayhawkfan
1983 - 2012 Ranger & B-Series
Sep 29, 2003 01:22 PM
