1962 vin #
Old May 7, 2012 | 09:20 AM
robert.mills's Avatar
robert.mills
1962 vin #
I have had my '62 f100 for about 8 years, and i have still not registered it, from what I understand they need to verify that my truck body matches the frame. I have no idea even where to begin looking for the VIN stamp on the frame. Does anyone have know where it might be?
Old May 7, 2012 | 10:53 AM
kjvforme's Avatar
kjvforme
Look on the top of the right frame rail in the engine compartment. Mine was about 1/2 way back from the front.
Old May 7, 2012 | 11:13 AM
kjvforme's Avatar
kjvforme
Sorry forgot to mention welcome to the FTE. Hey what VIN di you have on the registration or title?
Old May 7, 2012 | 11:26 AM
Buzz44's Avatar
Buzz44
Check the top of the passanger frame rail in two places. One should be stamped in under the cab and the other is somewhere between the cab and the core or radiator support. The one closer to the front is probably closer to the front of the frame rail probably between core support and the shock support tower.
Old May 7, 2012 | 11:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The VIN (Vehicle Identification Number) registers the entire vehicle, will be printed on the registration/title. It's also stamped on the Warranty Plate, which is located on the inside of the glovebox door 1961/62.
The hidden VIN's location is stamped on the top of the right (passenger) side frame rail, either in front of, or partially under the cab.
By now, the hidden VIN may be difficult to locate due to rust and road grime.
Old May 7, 2012 | 12:16 PM
robert.mills
Thank you all for the replays it has been very helpful. I will make sure to check as soon as I get a chance.
Old May 13, 2012 | 03:16 PM
Cazman1955's Avatar
Cazman1955
Please Id my VIN plate
F10JN291345
WB:114 COLOR: F MODEL: F100 TRANSAXLE: A11 GVW:5000 HP:114 RPM:3600 DSO:22
Thank you!
Old May 13, 2012 | 11:35 PM
kjvforme's Avatar
kjvforme
F10JN291345
Thank you!
F10 2 wheel drive
J= 223 CID 6 Cyl,
N= Norfolk, VA assembly plant
291345= Assembly Date May 1962
WB=114 Wheel base
Color code F= Baffin Blue
F100= 2 wheel drive 5000 GVW
Transmission A= Ford 3 Speed Manual Light Duty Transmission
Axle 11= Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
GVW= 5000 Lbs
Hp & RPM are to the 223 6 Cylinder engine
DSO= Domestic Service Order 22 Charlotte, North Carolina District Sales Office.
Old May 14, 2012 | 08:10 AM
Cazman1955's Avatar
Cazman1955
62 Stepside Vin ID.
Thank you! Very Much Appreciated.
Old May 14, 2012 | 10:26 AM
kjvforme's Avatar
kjvforme
You are one of five trucks built in model year 62 from Norfolk that I currently have on my unofficial registry.
Old May 17, 2012 | 10:04 AM
Cazman1955's Avatar
Cazman1955
62 Stepside Vin ID.
WOW, Thank you very much for letting me know. It makes my truck feel even more special to me!
Old May 17, 2012 | 10:19 AM
kjvforme's Avatar
kjvforme
Pretty nice looking truck you have there.
Old May 17, 2012 | 07:01 PM
Cazman1955's Avatar
Cazman1955
62 vin id
Rob,
Are you saying you only know of 5 trucks unofficially built in Norforlk, Va in model year 1962, or are you saying I have 1 of 5 Stepside unofficially built out of Norfolk for 1962 model year? Could you please tell me where I might find the official number of trucks built in Norfolk in model year 1962.
Thank you,
Tom
Old May 18, 2012 | 02:05 AM
kjvforme's Avatar
kjvforme
The list that I started two years ago has five trucks on it built in year 62. They built thousands in Norfolk that year, just only have these so far. 61-63 was the years that the unibody (integral) were built so many were gotten rid off because of the overloading problems. Of the five trucks, three were Unibody, two others where like yours, have one F350 that was flat bed.
Old May 18, 2012 | 07:43 PM
Cazman1955's Avatar
Cazman1955
62 vin id
wow Rob, I really appreciate the information. Yeah, I also heard of problems with the unibody flexing and causing the doors to open sometimes. Of course back then they didn't have seatbelts in the trucks so the driver or passenger would sometimes fall out of the truck. That is one reason I was happy to find this stepside.
Tom
