possably blown up?
Old May 8, 2012 | 02:07 AM
Dutch Semi's Avatar
Dutch Semi
One more thought and hopefully someone with more knowledge than I will chime in here but, what about the IPR? I thought I read that a bad oring on the IPR allows oil into the fuel (read: black fuel filter) and will cause a hard starting condition.
-Joseph
Old May 8, 2012 | 03:05 AM
bubba_3711's Avatar
bubba_3711
cps is from ford, i had that problem took me forever to figure out it was cps
Old May 8, 2012 | 05:44 AM
427 fordman's Avatar
427 fordman
Sounds like some injector problems...
Old May 8, 2012 | 07:53 AM
DIYMechanic's Avatar
DIYMechanic
Did I miss it? Did you check the fuel pressure at idle?
Old May 8, 2012 | 08:14 AM
Talyn's Avatar
Talyn
He said black filter.
I bet he has clogged injectors and algae.
He needs to run something to clean out the injectors and tank algae.
He's getting low fuel pressure cause everything is gummed up.
Old May 8, 2012 | 08:15 AM
Talyn's Avatar
Talyn
-Joseph
The IPR has no way to do anything with Fuel.
It simply controls pulsewidth of the HPOP system.
A bad IPR can cause hard starting, but I'm pretty sure this isn't his issue.
Old May 8, 2012 | 08:17 AM
Talyn's Avatar
Talyn
Double check first in your fuel bowl at what the filter looks like now you've changed it.
If the fuel is black and the filter is not slimey, you have oil in your fuel.
If it is black and the filter is slimey, or your old filter was slimey, go with the following steps.
Go get you a few fuel filters and some algaecide to get that scum out of the fuel system.
Grab some seafoam to help clean out the injectors.
When you get the algae out, mix some of the seafoam up with diesel in the fuel bowl after its clean to help clean out the injectors, and then put the rest in a gallon or 2 in the tank.
Want to run it really rich on the seafoam to clean out all the crap.
Old May 8, 2012 | 12:59 PM
strokin'_tatsch's Avatar
strokin'_tatsch
If the IPR is sticking it can cause the hard starting and extremely low power.
Old May 8, 2012 | 01:11 PM
Talyn's Avatar
Talyn
I said that. =)
Old May 8, 2012 | 01:15 PM
strokin'_tatsch
And just because the filter is black doesn't mean he has algae either. Could be injector o-rings, could it not?
Old May 8, 2012 | 01:19 PM
Talyn's Avatar
Talyn
I said that too.
Are you reading what I post?
well, I didn't say injector o-rings.
I just explained the steps if the filter was slimey.
I figured somebody would fill in the other parts for me.
one step at a time. I'd rather go for simple crap first thats easier to determine.
Old May 8, 2012 | 01:22 PM
strokin'_tatsch
I didn't read that post. I'm on my phone. I just saw someone mention algae b/c the filter was black. LOL
Old May 8, 2012 | 01:24 PM
  #28
Talyn's Avatar
Talyn
herpaderp.
Old May 8, 2012 | 01:27 PM
  #29
Talyn's Avatar
Talyn
He probably does need new injector o-rings in all honesty, but its better to check for the other stuff than to just freak out about pulling injectors right away.
he said something about blue smoke out the tailpipe, which is an o-ring symptom, and he's getting poor idle and low power.
His higher power setting is probably calling for high enough rail pressure that its firing the injectors a bit better, but still blowing lots into the cylinders too.
Go with the stuff that doesn't require tearing the motor apart is the direction I was steering things.
Old May 8, 2012 | 02:09 PM
  #30
444dieselrod's Avatar
444dieselrod
Here's what ya do...find a spray bottle and fill it with water. engine has to be stone cold, start engine, let it idle for a minute maybe. Start running around with your spray bottle and spray water on the manifold right where they meet the heads, only need to spray them once. The ones that evaporate the water off quickly are firing, the ones with water on them are not. Its alot easier than running around burning fingers trying to figure out which ones are not firing. once you know what cylinders arent firing pull valve covers off and start looking for oil squirting out the deflector spout.
I suspect you broke a nozzle spring and its got a cylinder or 2 loading up on fuel, hence the flame out the exhaust. You may have said it earlier but is it knocking really bad on one side of the engine?
