Max load in the bed
Absolutly not.
4k is getting up to nearly the weight of the whole truck.
Your payload limit is somewhere in the 1500 to 1800 lbs range +/- depending on the year, motor, tire size etc..
Over loading a lifted truck is really asking for trouble.
Go to the top of this page to articles and specs.
Go to specifications for your year and model and check it all out.
Good luck.
Good luck.
Means nothing without pics, but:
I have a trailer I made from a 1975 F150. I now has a wooded box on it with a 9inch Ford Axle with yoke removed. Yeah, weird thing, but the truck was junk and I needed a trailer.....
Anyway, I had to haul a load of sand and I have the scale ticket somewhere, but I was about 150 pounds short of 8,000 pounds of sand in the trailer from the sand pit! I pulled it 7 miles home with NO problems. I still use the trailer today, and nothing is broken from that.
Would NOT NOT NOT recommend it, tough.:
Built FORD tough, indeed!
Your trailer experiece means little either without some specs like the lisc. legal gross weight of the trailer etc.
The truck has a design limit and includes the whole truck not just the bed, back half frame and rear.
Big difference.
Pictures are of no value at all in either case.
Big difference.
8000 pounds on one 9inch axle is pretty good! The trailer is about perfectly balanced, and there was not much tongue weight. Maybe 600-700 pounds. It was small enough where my air shocks picked it right up no problem.
The loader at the pit gave me quite a look too!
I am just surprised I didn't blow a tire. They were just 15" load range "C" tires. I think they were rated to about 4000 for the pair??? Something like that. They were a SQUATT'N!!!!
But yes, no pics. I kept the scale ticket, but that means nothing because it doesn't have a pic of the trailer.
Again: DO NOT TRY IT!!! I would not do it again. ( I need my trailer not broken)
jaceqq
1983 - 2012 Ranger & B-Series
02-06-2008 11:03 PM
