Hi All,
This is my first post here.
I have an 80 model 150 4x4 with the 4.9. I have a hesitation problem when stepping on the gas.. like when changing gears and accelerating. I have changed the motor and put in a new long block from Ford. The problem was there with the old engine. I have rebuilt the carb, but did not run it thru a cleaner. I have installed a new vacuum advance. My uncle desmogged the truck years ago before I got it from my Dad. I know the truck did not do this when my Dad drove it. It sat for a number of years before I started the rebuild. I put a manual choke on it and if you pull the choke out a little, the hesitation is gone. I would also love to be able to get rid of all the electronic ignition and go back with a new distributor.
Any help would be greatly appreciated.
Welcome to the club. Did you use the original intake & exhaust manifolds? Did you have them planed before installing them? The carbed manifolds had a tendency to warp, causing vacuum leaks that would drive you crazy trying to find. Recommend you use the old propane test around the manifolds.
Hey Dynamo, welcome to the forum.
You mentioned you had a carb, but what kind is it?
I had a hesitation in my 86 f150 when i'd step on the gas. i have a holey 4180 and i tried everything to get rid of the stumble. What it ended up being is the accelerator pump cam. I bought the kit and i would put a different color on, take it for a test drive and see how it performed. I did this until i found one that got rid of the hesitation.
What this does is, the cams have different profiles (shapes) this alows them to operate the accelerator pump at different times and more or less volume.
I may not be an expert on these trucks, but this has been my experience with hesitation and stumble.
Yep, used the old intake manifold. I will check for leaks with a little propane. I just cant figure out why running some choke makes it stop.
Thanks for your help!
Running some choke would lessen the air in the combustion chamber, in a sense compensating for the extra air introduced by a vacuum leak.
I agree with both possibilities...especially with the note you stated about the choke. If limiting the air flow helps, then that mean maybe you have too much to begin with.
Either possiblity (vacuum leak or accelerator pump) would cause the engine to lean out. When you step on the gas, if you don't get that squirt of fuel as the throttle plates open up, that willl lean the engine out. Did you replace the accelerator pump when you rebuilt the carb? Is it adjusted correctly?
Look down the throat of the carb, with the engine off, and cycle the throttle wide open. Look to see that you have a nice solid stream of fuel squirting down the the throat.
On the distributor....you say you have an electronic ignition. I'm assuming you have a DS II. I would strongly recommend you keep this. They are very reliable and much better then the points type ignition.
I replaced the pump but probably did not adjust it correctly.
Well look down that carb and check for that squirt of fuel. That's a quick, and free, check to do. I'm not familiar with how the pumps on that carb is adjusted, if it's even adjustable. Your rebuild kit should have had some instructions.
For the vacuum leak check, if you don't have propane handy, you can also use some carb/choke cleaner or starter fluid if you have that.
It's been some time since the engine install and carb rebuild. The new engine has only a few hundred miles on it. The truck has sat a lot. I can't remember about the adjustment and the instructions are long gone. I will do both checks and go from there. Thanks for the help.
Looked down the carb and didn't see any fuel squirting in. This truck has a mechanical fuel pump so would any fuel be there without it running? Also sprayed some carb cleaner around the intake. Seems t o be a little change in rpm's around the #3 cylinder as well as #1. Also when the engine speeds up the hesitation is gone when you mash the accelerator quickly.
Yes, there would be fuel squirting, it would be coming from the Accelerator Pump. The pump's job is to provide a quick shot of gasoline to provide fuel to the air suddenly being sucked into the engine but for which the fuel circuit hasn't caught up yet.
If you don't have a properly-working accelerator pump, expect a short-lived hesitation when you initially step on the gas pedal.
Thats what it's doing. I am going to rebuild the carb again as it has sat for some time. I will definately have it cleaned this time and make sure everything is adjusted properly.
